Coding shifting paddles E90 automatic
12-31-2016, 04:14 AM | #1 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Hi everyone,
I would like to code the shifting paddles for my friend his car. This is a E90 with normal automatic. I did find some topics about this but never the right coding reference. Some mentiones $2XA but can't seem to find more info about it. Should adding $2XA and blank code the EGS module do the trick? Thanks and a happy new year for everyone. |
12-31-2016, 02:06 PM | #2 |
BimECU
193
Rep 759
yes thats the one,
but never blank code the module, use expert profile instead |
12-31-2016, 06:01 PM | #3 |
New BMW owner
139
Rep 621
01-05-2017, 09:09 AM | #4 |
253
Rep 775
01-06-2017, 03:55 AM | #5 |
No 55mph
1622
Rep 8,476
Why do you need to code to have the paddles work?
Retrofitted shift paddles on my 09' that didn't come with paddles from factory years ago - didn't need any coding just wheel/paddles/wiring harness
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-06-2017, 06:15 AM | #6 | |
329
Rep 325
I completed my retrofit & added a twist to it. I rewired the 335I paddles DCT style(left pull/downshift, right pull/upshift) & wired the "push" function of the paddle to activate Sport(DS) mode. |
01-09-2017, 11:56 AM | #7 |
202
Rep 749
Drives: 335i xDrive
When I retrofitted it to car did not need to code, spliced wires to trans + & -
01-09-2017, 01:37 PM | #8 |
238
Rep 947
01-13-2017, 07:06 AM | #9 |
329
Rep 325
I may look into the coding aspect of the paddles this weekend.
The diagram is steering wheel>junction box>transmission. The 2 yellow wires people pull from the back of the clock spring do indeed go to the junction box to the correct pins the diagram shows for paddle inputs. I checked on my car(06 325I which never even had paddles as a purchase option) & the wiring for the outputs from the clock spring to Junction box to transmission are there. I'm going to disconnect my paddle harness & connect the 2 yellow wires back up. There may be some additional coding to be done in the JBBF or some nettodat settings to play with. Either that or the paddle option may have to be manually added to the Daten file similar to DVD in motion & digital speedo on e65's. I've completed my retrofit & like it much better than the standard paddles, but for people who want to retrofit in the future, maybe there is a simpler solution if those 2 yellow wires are present in the clock spring already. |
01-13-2017, 07:40 AM | #10 |
66
Rep 208
Drives: San Marino blue 435i Gc
i did not code mine. there is a diy if you search. i pinned out wires behind the air bag and spliced wires at the shifter and they work great.
01-13-2017, 07:53 AM | #11 |
329
Rep 325
I didn't code mine either. But if it is possible to achieve by just purchasing the steering wheel & playing with some coding, it would be ideal for those doing this in the future.
