12-30-2016, 02:36 PM | #1 |
260
Rep 955
F30 Lane Departure retrofit - The correct way (w/button!)
In the spirit of contributing to a forum which has answered countless questions of mine:
Having just UNSUCESFULLY tried to retrofit 5AS with an FSC loaded KAFAS2 + emulator, I did not want to give up. I ordered what appears to be a set of buttons for an F01 series. The reason being, as many know, with the F30, its either lane departure + front colision warning, or neither. I know lane departure can be coded in, but I never liked the idea of not being able to turn it off. So I looked around, turns out lane departure was available as a stand alone option for the F01 series. Without further adieu: It works. I used the coding that is widely available. And threw in this set of buttons, and, yep... It works! Two things worth mentioning: A) You will need to order yet another set of F30 buttons that has JUST the 2 buttons (so essentially it will be FCW + LDW) because the F01 frame is different. B) The part #, that is in the images below... I can't seam to find it anywhere online :/ None of the parts catalogs have it. But I am sure if you look around you will find it. PS : To clarify: F30 (as far as I know) had only the following available: 5AG = Lane change warning 5AS = Lane departure warning + Front colision warning Front colision warning CANNOT easily be retrofitted as it requires FSC codes, which BMW will not sell you because its a "safety" system. Yeah its possible with an emulator, but it did not work for me. So the button set you order online will have either 5AG, 5AS or 5AG + 5AS. Here to answer any questions, enjoy! |
12-30-2016, 03:57 PM | #2 | |
356
Rep 688
Drives: 22 TR X3MC
2022 X3M Comp
2013 335i xDrive (Sold) |
12-30-2016, 04:01 PM | #3 |
1141
Rep 1,141
Nice find on the buttons. I did the 5AD retrofit a while ago, and since at the time I hadn't yet gotten the Front Collision Warning to work, my solution was to take the middle button piece from the 3 button panel and paint it matte black, but it never looked 100% right.
Not sure why you had an issue with the KaFas not working if it had all of the FSC codes, since you shouldn't have needed an emulator if that's the case(as long as you don't flash the KaFas). Mine had all the FSC's too which answered my confusion about why SLI was working without the emulator plugged in, and I was eventually able to get FCW working after figuring out the correct codes for the 6WB Instrument cluster. Since my car is MY2013, despite some attempts so far after retrofitting NBT, I have not been able to get 5AS to work(Driving Assistant/Pedestrian Detection). |
12-30-2016, 04:04 PM | #4 |
1141
Rep 1,141
Two different systems unfortunately. If you have the camera near the rain/light sensor on your windshield, then yes, you can add it via coding and the button. If not, then you would need to add the camera and replace the windshield, among other things.
12-30-2016, 05:45 PM | #5 | |
260
Rep 955
Here was my issue with the KAFAS2:
It needed to be flashed, the cafd was "not found" regardless of what pszdata I used. So I had no choice, had to flash it. I flashed it (used donor vin during flashing), then tried to code the donor VIN (what the FSCs were issued for) and no matter what I tried I could not get the module to accept the new (donor) VIN. Also, the final state of flashing, the part where it codes the default values to the module failed for the same reason that it wouldnt let me reset the module to the default values. I'll add, that the mistake I made was the module I bought was for a F34 NOT F30 (like my car)... So I had to 'reset' the coding data. Couldn't do it until I flashed it because of the cafd no existing Quote:
12-30-2016, 05:54 PM | #6 |
260
Rep 955
Yes.
You can even skip the button and have it 'default on'. I did not like this solution as I think its more correct to be able to turn it off. These are the coding instructions I used, and it worked perfect for me: http://www.bimmerfest.com/forums/sho...d.php?t=714122 |
12-30-2016, 07:56 PM | #7 | |
356
Rep 688
Drives: 22 TR X3MC
2022 X3M Comp
12-31-2016, 12:17 AM | #8 |
1141
Rep 1,141
Definitely need the camera for Lane Departure Warning... Speed Limit Info can be run from an emulator without adding camera, but no way to get LDW info without the camera
04-29-2017, 08:03 PM | #11 |
59
Rep 193
Guys, i was a able to retrofit lane departure on a car, however after coding the REM an error message appeared and never gone ' Rear-end collision warning failure' anybody have a clue?
05-01-2017, 04:41 AM | #12 | |
59
Rep 193
Plus, is it a specific type of an emulator? and from where can i get for the KAFAS camera |
02-19-2018, 04:14 AM | #14 |
Coding ECU's remotely
445
Rep 1,176
OP - do you have the wiring used for adding the buttons or can you direct me to them in ISTA+?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
02-19-2018, 09:21 AM | #15 | |
65
Rep 260
I have SLI already in the car from factory with KFAS2 and it has the latest flash. I tried it a while ago and got the Collision Warning which BMW had to clear I just said I dont know what happened If its as easy as setting it to ALWAYS on in the coding and it works Ill do it now Looking forward to the reply |
01-02-2019, 05:46 PM | #17 |
Rep 6
Hi friends, sorry about my poor english.
I have in my car 5AG-and more safety systems( Camera, Vibration in steering wheel and more.) I know that I must write in lane code this: 5AS. It is possible to activate it without a push button? Using the 5AG button? Thanks |
06-05-2020, 07:02 PM | #18 |
172
Rep 740
If anyone needs the drivers assistant switch from f01, i have one for sale.
https://f30.bimmerpost.com/forums/sh....php?t=1727483
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
08-01-2020, 10:28 AM | #20 | |
172
Rep 740
On the image below, you see that bulky part that wrapped? check there.
08-02-2020, 07:27 AM | #21 |
Rep 3
Thanks. So this means the plug is already there? Or loose wires?
08-02-2020, 07:28 AM | #22 | |
172
Rep 740
