12-29-2016, 06:35 PM | #1 |
Rep 7
Drivetrain
Hello folks! My bmw 328i f30 start having drivetrain problem after changing the 4 sparks. The car would feel like lack of fuel then drivetrain will appear on idrive.
I've changed Sparks Fuel injectors Oil Transmission oil with new filter. Nothing seems to help I went to dealer and he said the car is okay but whenever I press on gas pedal till the end the car start cracking Like lack of fuel and boom drivetrain appears. I've done everything possible nothing seems to work. I've never had this problem before changing the bloody sparks Any help? Thanks Last edited by yousefmos; 12-29-2016 at 07:03 PM.. Reason: N20 |
12-30-2016, 01:25 PM | #3 |
BimmerPost Supporting Vendor
24292
Rep 190,975
+1
12-30-2016, 02:06 PM | #4 |
Big Turbo Boys N Girls
327
Rep 579
Buy OEM Spark Plugs. Or check the gap on the ones you put in. Also Coil packs might be an issue as well. Code reader will be your best friend or take it to the Stealership and have them check it out and do a test drive with the tech to show him the issue.
12-30-2016, 05:19 PM | #6 |
327
Rep 579
Also might be that you maybe mixed up the coil packs when putting them in but shouldn't really matter as they are universal but car breaking up on the top end more than likely is bad spark plugs or loose spark plugs (not tightened correctly).
01-01-2017, 02:24 AM | #7 |
264
Rep 953
This happened to me as well. Took my car into the dealer and they gave it back with a CEL after replacing the spark plugs. They claimed it had to be from my catless downpipe but I told them it couldn't be. So I went home to check it out and had no codes pop up, went back to the dealer told them that it was their fault since it happened on their end, told them I wouldn't leave until it was fixed. Got the car back and the SA said it was the turbo pressure line, said it was hard to tell because of everything I had done to the car.
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
01-03-2017, 01:48 AM | #8 |
Rep 7
i did buy the original BMW sparks. i've never had such problem before changing the spark and i just want to know if drivetrain has any connection with transmission box or no. thanks
01-03-2017, 01:49 AM | #9 |
Rep 7
hi and thanks for reply. i haven't got ant code only drivetrain error appears on my screen i don't even know how to get the code. should it appear on screen as well? thanks
01-03-2017, 01:58 AM | #10 |
Rep 7
when i had the error appeared on my screen i went to the dealer and have it checked he said the fuel injector not working so i replaced them after replacing the injector the problem still.... so i have almost changed everything.
coil sparks fuel injector i just don't know what else to do and what to change. I'm planning to insert the old sparks on tomorrow and see how it goes. thanks. |
Tags |
drivetrain |
