Widest tire I can run
12-28-2016, 08:51 PM | #1 |
50
Rep 347
Was just wondering what tire width possibilities I can run for my cars OEM rims style is
http://www.realoem.com/bmw/enUS/show...diagId=36_1288 Planning to get the widest tire I can without modifying the fenders etc as I do not much know much about it. Currently on 25/45/17 as the car came with it, any information would be provided thank you |
12-28-2016, 10:06 PM | #2 |
2032
Rep 8,339
What wheel size with offset, suspension mods, pre-lci or lci, body style? All these play a factor. I have 305s out back. Some guys have fit 255 front. I have 245 front.
12-29-2016, 08:28 AM | #3 | |
Guest
Rep n/a
Drives:
Look around OP. Some guys have done 255/40/17 on stock wheels (which is as wide as you can safely go) and it looked really meaty most anything between that and the stock size should fit fine. |
feuer4275.50 |
12-29-2016, 08:53 AM | #4 |
2032
Rep 8,339
If the wheel you posted is going to be used front and rear 255. However I f you are using an 8.5 fotr the rear, 265. If you are using 8" front and rear however inwould suggest 245 on all 4 so you have a square setup and can rotate.
feuer4275.50 |
12-29-2016, 01:24 PM | #5 |
50
Rep 347
Sorry I'm not much of a tire guy , more into performance and cosmetics. 8 inch wheel on all 4 tires, LCI, suspension wise everything stock ,
So 245/45/17 all around is possible ? |
12-29-2016, 02:03 PM | #6 |
87
Rep 471
I have been researching this and it looks to me that 8.5" is the widest square set up you can do without rolling fenders or altering the alignment to get the front wheels to fit.
18x8.5 wheels would fit a 225/40R18 tire, maybe 255/35R18 17x8.5 wheels would fit a 225/45R17 tire, maybe 255/40R17 You can go wider in the rear if you want staggered set up, which tends to produce more unwanted understeer, in my opinion, especially if you have less than 300 hp. You might be able to fit slightly larger tires, but the smaller tire is what Tire Rack recommends for a square set up and the larger is what BMW uses for that width on the rear when using the staggered set up. You would want to keep the offset around 30mm to 40 mm. Here is a recent discussion related to this: http://www.e90post.com/forums/showthread.php?t=1326419
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
12-29-2016, 02:03 PM | #7 |
76
Rep 193
12-29-2016, 02:04 PM | #8 |
2032
Rep 8,339
12-29-2016, 02:07 PM | #9 | |
76
Rep 193
12-29-2016, 02:09 PM | #10 |
2032
Rep 8,339
Youre kinda in the middle of 40 and 45 profile. 40 is 24.7". 45 is 25.6" oem is 25". I run 26". Speedo is correct at about 26" so smaller = more speedo error, lighter, worse mpg, better acceleration, less sidewall, better handling, rougher ride. Up to you but either works.
12-29-2016, 03:23 PM | #11 |
50
Rep 347
Okay so running 245/40/17 all around is possible I guess the only difference will be the tire dimension going from 45 to 40 which isn't a big issue. Correct me if I'm wrong
Thanks again for all the help guys sorry I'm such a major noob on tires lol |
12-29-2016, 03:28 PM | #12 | |
76
Rep 193
Don't apologize, this is one of the ways you learn. |
12-29-2016, 09:46 PM | #15 |
2032
Rep 8,339
Where do you live? Driving style? For temps over 40F and spiruted driving Michelin PSS can't be beat. I'd have those as summer tires and a second set for winter if i lived in an area with changing seasons.
12-29-2016, 11:09 PM | #16 |
50
Rep 347
Vancouver, Canada right now its 0 degrees Celsius so 32F , it'll be like this till February and from there on growing temperatures, usually the max we get is 86F during the summer times. I don't do much cornering usually just people going too slow in the left lane and the occasionally red light launches , just wanting to get the best all season available because it rarely snows here
12-30-2016, 04:36 PM | #18 |
87
Rep 471
The comments I have observed from those running wider than 8.5" on the front always say the camber and/or the fenders need to be rolled. Maybe with the perfect offset or something, but the majority cannot do it without adjusting the camber or fender rolling, as best that I can tell. It is not offered by BMW on any OEM set up or for sale by TireRack, admittedly they are not pushing the limits, but they must be doing that for a reason.
12-30-2016, 05:00 PM | #19 | |
76
Rep 193
Bluewater328iT86.50 |
12-30-2016, 05:08 PM | #20 |
87
Rep 471
Good to know. Are those 18 or 19" wheels?
12-30-2016, 05:11 PM | #21 |
76
Rep 193
