12-28-2016, 09:39 AM | #1 |
50
Rep 88
LCI LED Headlight LED sidemarkers in headlight
Has anyone coded out the LED sidemarkers in the headlights (LED)? My coder can do it on xenon headlights but has not figured out how to shut them on the LCI LED headlights. Any suggestions?
2016 LCI F30 |
12-29-2016, 04:05 AM | #2 |
451
Rep 1,201
Yes, it is possible. You need to look inside the two FLE modules.
If you can provide line of hex codes currently in DRL_idx, POLI1_idx, POLI2_idx and POLI3_idx they will look something like: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 I'll tell you which ones to code to off.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
12-30-2016, 11:47 AM | #3 |
556
Rep 906
Coded mine off last night:
FLE43/3006/LM_ID_LT04: Change Werte=04 to Werte=00 FLE43/3006/LM04_Name: Change Werte=0D to Werte=00 FLE44/3006/LM_ID_LT04: Change Werte=04 to Werte=00 FLE44/3006/LM04_Name: Change Werte=0D to Werte=00
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-30-2016, 01:24 PM | #4 |
451
Rep 1,201
How did you work this out? Be interesting to hear as this is a slightly different way to how I would do this.
12-30-2016, 07:44 PM | #5 | ||
556
Rep 906
12-31-2016, 03:09 AM | #6 | |
451
Rep 1,201
It would be much safer to assign the LED off setting group to the side markers, only in the POLI1_idx, POLI2_idx and POLI3_idx, rather than change a value that may be used elsewhere. Without going through the entire table of LED groups and settings, It's difficult to tell. It may be ok and it's had no other unintended consequences. However, you may have also coded out something as minor as the indicators flashing when the alarm goes off or something important like flashing your headlights. It's been more luck than judgment it worked for you unless you have a F15
12-31-2016, 08:49 AM | #7 | |
556
Rep 906
I'll double check if I broke anything else, but in the meantime here are the hex values from my car: DRL_Idx: 00, 00, 00, 00, 00, 00, 04, 00, 00, 00 POLI1_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 POLI2_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 POLI3_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 FLE43 and FLE44 have the same values.
12-31-2016, 09:48 AM | #8 | |
451
Rep 1,201
The other way is as follows: Each one of the ten pairs in the settings correspond to a LED group. inner or outer High beams, inner or outer low beams, side markers, eyebrows and various others to shape the adaptive beams. This can vary from country to country, model to model and if you have adaptive or non-adaptive LED. The individual two bit hex code is then the setting for brightness, dimming, how they turn on and off etc. For example, in your settings, the seventh pair controls the DRL halo rings. You can see the setting code goes from 04 in DRL_idx to 06 in POLI1_idx, 2 and POLI3_Idx. The setting code 04 is 100% brightness and setting code 06 is 43% brightness. This is the halo dimming when the lights get turned on. DRL_Idx : 00, 00, 00, 00, 00, 00, 04, 00, 00, 00 POLI1_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 POLI2_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 POLI3_Idx: 00, 00, 00, 05, 00, 00, 06, 00, 00, 00 It looks like the forth pair are unique to US cars, so these probably control the side markers. Try setting them to 00 as setting 00 is off (or can be overridden by other settings) DRL_Idx : 00, 00, 00, 00, 00, 00, 04, 00, 00, 00 POLI1_Idx: 00, 00, 00, 00, 00, 00, 06, 00, 00, 00 POLI2_Idx: 00, 00, 00, 00, 00, 00, 06, 00, 00, 00 POLI3_Idx: 00, 00, 00, 00, 00, 00, 06, 00, 00, 00 Remember to do each FLE as they correspond to the left and the right headlight respectively.
12-31-2016, 07:11 PM | #9 | |
556
Rep 906
Both side-markers stayed on while on low-beams. Then, I VO-coded FLE43 and FLE44 again and then FDL-coded back to the F15 values I mentioned earlier. Tested all the lighting scenarios I could find and didnt see anything out of the ordinary. Not a lot of test cases since I'm on non-adaptive LEDs. Dont think it will help, but I'm on a F020-16-11-502.
01-01-2017, 09:35 AM | #10 | |
451
Rep 1,201
However, I looked deeper into your solution and worked out what it does. I have to admit it's a better solution for turning off the side markers than I proposed. What happens is you are deactivating the mappings for the side marker LED's This disables the 4th pair in the 10 bit settings. The 4th pair only deals with the side markers setting it to a null value 00 This disables the mapping of that 4th pair to the LED group itself. 0D in HEX is 13 and looking at how the LED groups are numbered 13 = SML1. Again setting it to a null value of 00 that doesn't exist. 1 = LB1, 2 = LB2, 3 = LB3, 4 = HB1, 5 = HB2, 6 = HB3, 7 = DRL1, 8 = DRL2, 9 = DRL3, 10 = CL1/ML1, 11 = CL2/ML2, 12 = CL3/ML3, 13 = SML1, 14 = SML2, 15 = SML3, 16 = FRAZ1, 17 = AZL1, 18 = AZL2, 19 = AZL3.
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-01-2017 at 10:29 AM.. Reason: Hex |
01-01-2017, 12:10 PM | #11 |
556
Rep 906
Awesome!
I'm all for elegant solutions, but don't thank me, thank whoever figured it out on the F15.
01-01-2017, 12:37 PM | #12 |
2374
Rep 8,364
01-01-2017, 01:21 PM | #13 |
451
Rep 1,201
Neat solution
This should work across platforms as pair 4 is mapped to the side markers on US cars. It can also be mapped to AZL1 in LED group 17
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-01-2017 at 01:32 PM.. |
Almaretto2374.00 |
01-01-2017, 06:11 PM | #14 | |
2374
Rep 8,364
01-02-2017, 08:05 AM | #15 |
451
Rep 1,201
I can't even see the side marker LED's on my lights. I don't think they exist on EU spec cars.
The only EU legal requirement to have yellow side markers are vehicles over 3m (10ft)
01-02-2017, 09:34 PM | #16 |
2374
Rep 8,364
Some EU headlamps do not come with them, so no amount of coding can overcome hardware limitation.
01-03-2017, 07:05 AM | #17 | |
electrified
32
Rep 127
If i wan't to try and locate said lamps where about would i find them? |
01-04-2017, 02:05 AM | #18 |
2374
Rep 8,364
01-04-2017, 02:18 AM | #19 |
electrified
32
Rep 127
01-04-2017, 02:34 AM | #20 | |
2374
Rep 8,364
Newer units, will only have 3 little lights, like my profile pic (my F010 with 552 LED Adaptive lights). Last edited by Almaretto; 01-04-2017 at 02:44 AM.. |
08-16-2019, 12:40 PM | #21 |
Rep 13
Hello, will you help turn off the front marker lamps from the USA in the BMW F48 (X1).
Unfortunately, the above descriptions do not match. Thanks in advance for the hints. |
08-17-2019, 08:22 AM | #22 | |
1790
Rep 3,056
If you have any problems, let me know, I will help.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
