12-27-2016, 08:00 PM | #1 |
173
Rep 278
435d Engine takes a long time to get up to temperature
Hi,
Previously i owned a 2013 F10 535d 313ps. I now own a 2015 F36 435d 313ps. The same engine right ? How come the 435d takes so much longer to get up to 100 degrees operating temperature than my 535d did. After my 10 mile journey to work the engine still sometimes fully isnt up to temperature, when in my 535d after 5 miles it would be up to temperature. I have noticed the 435d doesn't have flaps behind the grille like the 535d did, could this be the reason why ? Thanks
Speed Yellow 435d GC
400 BHP & 839NM My Rare Bmw Visit: http://f30.bimmerpost.com/forums/sho...8#post21668058 |
12-28-2016, 03:54 AM | #3 | |
741
Rep 2,511
My F30 330d took my entire 12 mile commute to hit operating temperature. The E90 had no temperature gauge, so it's hard to tell if the engine size and flaps made a difference. However, my B58 340i with its redesigned cooling loop warms up much quicker than the N57 diesel unit. Granted Petrol units always warm up quicker. However, my outbound commute at urban speeds isn't significantly quicker. I think both units don't develop much heat at very low loads. On my homeward trip where the national speed limit section is much earlier the Petrol warms up about 5 miles before the diesel did. I think the diesel unit uses its surge of low down torque so effectively that it doesn't do enough work to warm through. For the Same unit in a 4 vs a 5 it will do even less work moving the smaller lighter car. Combined with the absence of flaps and you get a longer warm up time.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
12-28-2016, 03:58 AM | #4 |
114
Rep 257
Hi
I'm not sure about the 535d but the F series 335d gauge shows oil temperature not coolant. The block gets warm very very quickly for a diesel. You can be geeky like I did when I first got it and stop to check the top hose (I didn't see the oil can on the gauge) but also on cold days you can see the oil temperature stagnate and even drop a little after about 4-5 miles as valves open. That is when it is warm. |
12-28-2016, 04:19 AM | #5 | |
10996
Rep 32,881
12-28-2016, 04:25 AM | #6 |
310
Rep 1,338
Drives: 2014 F30 320D X-Drive
I have noticed that my 320d will take time to warm up and also very quick at loosing heat for instance parking to do 30 mins shopping
12-28-2016, 04:33 AM | #7 |
741
Rep 2,511
My E90 was a 2009 N47(?) LCI model. I think these all did.
12-28-2016, 04:39 AM | #8 | |
1777
Rep 3,490
My 330d (Sdrive) used to take at least 7 - 10 miles for the needle to say the oil was up to temperature. (No flaps I believe) I have another 330d (X-Drive) on the fleet which also takes 7 to 10 miles. (No flaps again) I have a F34 (35d XDrive) on the fleet which also takes 7 to 10 miles. (Has the flaps iirc) As for the F06 4d. Now for some strange reason this thing is up to operating temp within 2 - 3 miles. (Has flaps) Today was the first day since xmas eve that I had driven the F06. It was also -1c outside. Like clockwork the thing was supposedly up to operating temp within 3 miles. I'm half tempted to do an oil and filter change just to see if there was some dud oil out of the factory and log a job with BMW but thought I would see what you guys have to say about it first. TIA |
12-28-2016, 05:02 AM | #9 | |
741
Rep 2,511
Zoom in and you can see the flaps.
12-28-2016, 06:20 AM | #10 |
834
Rep 2,116
My 335d takes pretty much my entire 13mile commute to get up to 100.
I try not to push it too hard until it gets there but is this required or am I being overly protective? |
12-28-2016, 06:33 AM | #11 |
1777
Rep 3,490
12-28-2016, 08:06 AM | #12 | ||
243
Rep 710
12-28-2016, 08:12 AM | #13 | ||
243
Rep 710
12-28-2016, 08:56 AM | #14 | |
114
Rep 257
12-28-2016, 08:58 AM | #15 |
591
Rep 1,797
I think it's just the big torque meaning the engine isn't working hard, I was normally 15 miles into my commute, 10 miles down the mway before mine warmed up
G20 M340i
Gone F36 435d F30 335d |
12-29-2016, 04:48 AM | #16 | |
1777
Rep 3,490
Nope, definitely a oil temperature gauge. |
12-29-2016, 06:51 AM | #17 | |
6659
Rep 15,858
My 535i 'petrol' (more waste heat) will take around 12 miles at 0C, to get oil over 100C. If I drive down the glen, 12 miles (most of the trip at ~60mph), oil will not even get to 95C. |
