12-27-2016, 05:51 PM | #1 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Runtime Error When Trying to Edit FDL?
Does anyone have any experience with getting runtime errors anytime you try to edit the FDL? The error I'm getting is C027, and is a java null pointer exception. Thanks.
12-27-2016, 06:19 PM | #2 |
2374
Rep 8,364
Which E-sys and Launcher version are you using?
Does this only occur when you Right Click orange CAFD > EDIT or when you load NCD in FDL-Editor as well? |
12-27-2016, 06:47 PM | #3 |
4017
Rep 3,540
E-Sys version is 3.28.1 and the launcher is 2.6.2.124.
I've only ever tied right clicking the CAFD files and selecting "edit." Haven't made it to the FDL editor yet, haha. |
12-27-2016, 07:34 PM | #4 |
2374
Rep 8,364
12-27-2016, 09:52 PM | #6 |
2374
Rep 8,364
12-28-2016, 04:46 PM | #7 |
4017
Rep 3,540
Thanks for the suggestion of doing "offline" coding Almaretto. I was able to make all the changes I wanted that way and successfully loaded them to the car.
12-28-2016, 05:52 PM | #8 |
2374
Rep 8,364
01-02-2019, 03:58 AM | #9 |
Rep 15
Runtime Error When Trying to Edit Fa(vo)
Hi,
when I save FA and next click "Edit" I have this error and I can't add and edit FA(VO) equipment car https://allegro.zapodaj.net/24d296e7852d.jpg.html someone had a similar problem? I can change FDL and edit, coding it's work's but no work edit FA (VO)... greetings Last edited by michalmkr; 01-03-2019 at 03:57 AM.. |
01-02-2019, 09:14 PM | #10 | |
2374
Rep 8,364
01-04-2019, 03:27 PM | #14 |
Rep 15
Almaretto, thank you for the hint I will check tomorrow whether it will work properly.
I still have questions: - coding FDL HU_ENTRY I have selected options to show it's software version. It turned out that I have from 26.06.2013r. That's why I would like to update HU_ENTRY now. CMB_MEDIA I updated with the USB port in the armrest to the last version 1008. I just found out that I can update ECU's using E-sys. (Before I thought that only Ista could be) Any ECU's I can updated on a running engine? Only ECU DME can not update on running engine? - how to check the version of the remaining ECUs? I do not have Ista. In the E60 versions of the software I saw in Inpa. In F30 after connecting to Inpa, I can not find this information anywhere ...
01-04-2019, 03:31 PM | #15 | |
2374
Rep 8,364
01-07-2019, 08:23 AM | #16 |
Rep 15
you were right! after installing E-Sys 3.27.1 with Launcher Premium V2.6.0.119 everything works as it should, I can add Vo! Thank you Almaretto
01-08-2019, 04:05 AM | #17 |
2374
Rep 8,364
01-08-2019, 07:48 PM | #18 |
Rep 15
Almaretto, help!
https://zapodaj.net/ae86b956fef27.jpg.html https://zapodaj.net/292e282282de1.jpg.html I want change my VIN on CMB_MEDIA because I want activate internet and BMW Life and something went wrong - my wife called to me and started to turn my head back, after the conversation it was all over... There is no CAFD, how can I fix it? Greetings
01-08-2019, 11:21 PM | #20 | |
2374
Rep 8,364
michalmkr1.50 |
01-12-2019, 01:20 AM | #22 |
2374
Rep 8,364
