12-26-2016, 03:01 PM | #1 | |
568
Rep 1,291
retrofitted ASD, but not working, need to reflash
Hi
So I retrofitted the ASD module, and it shows up in ESYS. But doesn't work. I've got exactly the symptoms described in this thread: http://f80.bimmerpost.com/forums/sho...2#post21032492 And the result is I need to reflash the module. So I followed this guide here: http://www.bmwesys.com/guides/E-Sys%...CU%20Guide.pdf Problem seems to be that for some reason the procedure I'm following doesn't find the ASD needs a reflash Here's the TAL-processing output: Quote:
SVT_ist.xml shows HTML Code:
<ecu baseVariant="ASD"> <diagnosticAddresses> <diagnosticAddress physicalOffset="63"/> </diagnosticAddresses> <ecuDetailInfo ActiveNotifyEnabled="true" SWTEnabled="false" SecurityEnabled="false" NGSCEnabled="false" CodingEnabled="true" FlashEnabled="true" ISO14229Enabled="true"/> <standardSVK progDepChecked="1" SVKVersion="1"> <partIdentification> <processClass>HWEL</processClass> <id>00000F94</id> <mainVersion>003</mainVersion> <subVersion>003</subVersion> <patchVersion>000</patchVersion> </partIdentification> <partIdentification> <processClass>CAFD</processClass> <id>00000F9B</id> <mainVersion>001</mainVersion> <subVersion>026</subVersion> <patchVersion>000</patchVersion> </partIdentification> <partIdentification> <processClass>BTLD</processClass> <id>0000111C</id> <mainVersion>002</mainVersion> <subVersion>000</subVersion> <patchVersion>001</patchVersion> </partIdentification> <partIdentification> <processClass>SWFL</processClass> <id>0000111D</id> <mainVersion>002</mainVersion> <subVersion>007</subVersion> <patchVersion>006</patchVersion> </partIdentification> <partIdentification> <processClass>SWFL</processClass> <id>000021D4</id> <mainVersion>001</mainVersion> <subVersion>019</subVersion> <patchVersion>000</patchVersion> </partIdentification> </standardSVK> <ecuStatusInfo hasIndividualData="false" Bit6="false" Bit5="false" unsupportedSVKVersion="false" ECUChanged="false" ecuContainedInSVTSoll="true" RequestSVKResponse="true" identityCheck="true"/> <ecuBusConnectionInfos> <ecuBusConnectionInfo busID="1" busType="BODY_CAN"/> </ecuBusConnectionInfos> <ecuDiagBusConnectionInfo busID="1" busType="BODY_CAN"/> <gatewayDiagnosticAddress physicalOffset="16"/> </ecu> SVT_tal.xml shows this: HTML Code:
<talLine diagAddress="3F" baseVariant="ASD" status="Executable" id="tl_2"> <hwDeinstall status="Executable"> <hwDeinstallTA status="Executable"> <sgbmid> <processClass>HWEL</processClass> <id>00000F94</id> <mainVersion>003</mainVersion> <subVersion>003</subVersion> <patchVersion>000</patchVersion> </sgbmid> </hwDeinstallTA> </hwDeinstall> </talLine> Basically both the RDC and the ASD that I retrofitted do not appear in the installedECUList_Soll -> Where are they missing for the TAL calculation to find them and put in the SVT_soll.xml? HTML Code:
<installedECUList_Ist> <ecuID diagnosticAddress="32" baseVariantName="RDC"/> <ecuID diagnosticAddress="63" baseVariantName="ASD"/> <ecuID diagnosticAddress="18" baseVariantName="DME2"/> <ecuID diagnosticAddress="6" baseVariantName="TRSVC"/> <ecuID diagnosticAddress="118" baseVariantName="VDC1"/> <ecuID diagnosticAddress="7" baseVariantName="SME2"/> <ecuID diagnosticAddress="1" baseVariantName="ACSM"/> <ecuID diagnosticAddress="109" baseVariantName="SM2"/> <ecuID diagnosticAddress="16" baseVariantName="FEM_GW"/> <ecuID diagnosticAddress="48" baseVariantName="EPS"/> <ecuID diagnosticAddress="103" baseVariantName="ZBE3"/> <ecuID diagnosticAddress="28" baseVariantName="ICM"/> <ecuID diagnosticAddress="58" baseVariantName="EME2"/> <ecuID diagnosticAddress="24" baseVariantName="EGS"/> <ecuID diagnosticAddress="93" baseVariantName="KAFAS2"/> <ecuID diagnosticAddress="23" baseVariantName="EKPM2"/> <ecuID diagnosticAddress="86" baseVariantName="FZD"/> <ecuID diagnosticAddress="97" baseVariantName="TCB"/> <ecuID diagnosticAddress="114" baseVariantName="REM"/> <ecuID diagnosticAddress="53" baseVariantName="TBX"/> <ecuID diagnosticAddress="41" baseVariantName="DSC"/> <ecuID diagnosticAddress="94" baseVariantName="GWS"/> <ecuID diagnosticAddress="96" baseVariantName="KOMBI"/> <ecuID diagnosticAddress="99" baseVariantName="HU_NBT"/> <ecuID diagnosticAddress="120" baseVariantName="IHKA3"/> <ecuID diagnosticAddress="64" baseVariantName="FEM_BODY"/> </installedECUList_Ist> <installedECUList_Soll> <ecuID diagnosticAddress="18" baseVariantName="DME2"/> <ecuID diagnosticAddress="6" baseVariantName="TRSVC"/> <ecuID diagnosticAddress="118" baseVariantName="VDC1"/> <ecuID diagnosticAddress="7" baseVariantName="SME2"/> <ecuID diagnosticAddress="1" baseVariantName="ACSM"/> <ecuID diagnosticAddress="109" baseVariantName="SM2"/> <ecuID diagnosticAddress="16" baseVariantName="FEM_GW"/> <ecuID diagnosticAddress="48" baseVariantName="EPS"/> <ecuID diagnosticAddress="103" baseVariantName="ZBE3"/> <ecuID diagnosticAddress="28" baseVariantName="ICM"/> <ecuID diagnosticAddress="58" baseVariantName="EME2"/> <ecuID diagnosticAddress="24" baseVariantName="EGS"/> <ecuID diagnosticAddress="93" baseVariantName="KAFAS2"/> <ecuID diagnosticAddress="23" baseVariantName="EKPM2"/> <ecuID diagnosticAddress="86" baseVariantName="FZD"/> <ecuID diagnosticAddress="97" baseVariantName="TCB"/> <ecuID diagnosticAddress="114" baseVariantName="REM"/> <ecuID diagnosticAddress="53" baseVariantName="TBX"/> <ecuID diagnosticAddress="41" baseVariantName="DSC"/> <ecuID diagnosticAddress="94" baseVariantName="GWS"/> <ecuID diagnosticAddress="96" baseVariantName="KOMBI"/> <ecuID diagnosticAddress="99" baseVariantName="HU_NBT"/> <ecuID diagnosticAddress="120" baseVariantName="IHKA3"/> <ecuID diagnosticAddress="64" baseVariantName="FEM_BODY"/> </installedECUList_Soll>
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 12-26-2016 at 03:12 PM.. |
08-30-2018, 03:33 PM | #2 | |
35
Rep 277
I have the same problem, did you found sollution, cause don't know what to do. |
