12-26-2016, 02:20 PM | #1 |
Moon Parasite
655
Rep 1,336
Is it possible to code out the trunk opening from the remote ?
Looking to see if we can code out/off the opening of the trunk from the remote to prevent the FOB opening the trunk while in your pocket. Has anyone done this yet ? I searched but didn't find an answer.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
12-28-2016, 05:01 AM | #2 |
Moon Parasite
655
Rep 1,336
BUMP - No one out there have any idea ? Bueller Bueller ?
12-28-2016, 06:21 PM | #3 |
260
Rep 955
There is a setting somewhere to set the amount of time one has to hold the button on the remote down before the trunk opens.
Guessing you can max this out and at least make it very unlikely someone will attempt to hold the button down that long. |
CIWS655.00 |
12-28-2016, 08:13 PM | #4 |
Moon Parasite
655
Rep 1,336
That's an interesting idea, thanks.
12-31-2016, 05:09 AM | #6 |
260
Rep 955
All depends on what OP is after.
I'm EU so we dont get the switch in the glove box... But I am assuming this locks ALL access to the trunk. Including the outside handle button and (if you have one) the interior drivers knee area button. |
12-31-2016, 05:29 AM | #7 |
Moon Parasite
655
Rep 1,336
Best case would be to prevent unintended trunk openings occurring because the button on the remote gets pressed while the remote is in the pocket when bending / kneeling, etc But still allowing it to be opened from the release inside and outside the car. I never really use the button on the remote to open it. I purchased and tried the BMW MSport leather remote cover and it still happens.
12-31-2016, 07:57 AM | #8 | |
260
Rep 955
Yep looks like this is as close to a solution as you will get:
FEM_BODY 3040 CLM_TIMEOUT_HK_SMO Change the Comfort Access trunk opening delay. (HEX value by 0.1 secs) Unless you are brave enough to open up your remote and unsolder or block the button. EDIT : Should note, I am not 100% sure if this is the correct setting. This may not be it. I am sure this exist though. I have it coded in my E92 M3. I found the opposite... Annoying that I had to hold the button down for so long to get the trunk to pop open. Quote:
CIWS655.00 |
01-01-2017, 06:37 AM | #10 |
Moon Parasite
655
Rep 1,336
Thanks folks, will see what I can come up with.
01-02-2017, 04:30 PM | #11 |
Rep 4
I don't have an answer for you but I can sympathise having had the same problem with finding all the windowss open one morning. I was able to code out that option so there maybe a similar option for the trunk
01-02-2017, 07:58 PM | #12 |
Moon Parasite
655
Rep 1,336
Tried this afternoon, setting the value to 00 vs 01 hoping it might disable, but it didn't. Just took the opening delay out so it popped right open.
01-03-2017, 10:43 AM | #14 |
56
Rep 144
Did you try going in the opposite direction and making it much higher number, like 09? Not sure what the top value of the range is, but definitely lowering it reduces the delay, not what you're after.
01-03-2017, 02:35 PM | #15 |
260
Rep 955
Exactly.
Also worth mentioning, even if a value is not there, you can try entering a custom value for 60 seconds or something. First try the highest value, let the car sleep a few minutes and see if it helps. If it does, keep going up with custom values until you reach a point you feel comfortable with. |
01-03-2017, 05:44 PM | #16 | ||
Moon Parasite
655
Rep 1,336
I changed the wert value from 01 to 00. The only two options available. I think y'all are referring to the Werte value which is default to 05 in my case. When wert was changed to 00, Werte also changed to 00. My assumption here is wert is a delay on or off (01 or 00) As it turns out there was no delay with that setting, the trunk popped right open. I could be off base here, but if Werte is a delay setting then increasing the number is only going to delay how long it takes before the trunk pops open after the button is pressed, not stop it from opening, which is the goal I'm after. Would you agree, or am I looking at it wrong ?
01-03-2017, 07:44 PM | #17 | |
260
Rep 955
Yes. Its going to increase the time needed to hold the button.
That being said, if you are able to increase it to lets say 30 seconds, you'll be pretty close to what you are after. Try changing the value to 10 by right clicking Werte and editing it to 10. See if that increases the time you have to hold the button. Those values are usually in hex ( http://www.binaryhexconverter.com/de...-hex-converter ). So for example, 30 would be: 1E Also, they are usually fractions of a second. So with 1E (30) as an example, it could be 30 x 0.5, or something along those lines. Note : Just to be clear, those Werte values can be modified even if its not one of the "choices". You can set manual values in there by editing them manually by doing the right click -> edit I mentioned. As always, proceed at your own risk. I have NEVER EVER had any issues setting custom values (even with things like how soon the alternator should switch on when car starts, etc)... Quote:
CIWS655.00 |
01-03-2017, 08:06 PM | #18 |
2374
Rep 8,364
RC_TIME_DELAY_BOOTLID (RC TIME DELAY BOAT EYELID)
wert_01 (value 01) = 05 Comment = timeout for delayed open control of the bootlid (HKL) 1 unit = 0, 1s value range: 0... 2s note: overall delay value is the sum of CLM TIMEOUT RC BTL (CL-master) and RC TIME DELAY boat EYELID (component in remote control) delay time to the electrically opening of HK - should be added for F020 when available in container: (building level > = 0703) + 316 tailgate LIFT OPTIONS wert_00 (value 00) = 00 - Comment = Verzögerung in Einheiten von [0,1s], wert_00 entspricht 0,0s. (Delay in units of [0, 1s], value 00 is equal to 0, 0 s.) wert_01 (value 01) = 05 - Comment = Verzögerung in Einheiten von [0,1s], wert_01 entspricht 0,5s. (Delay in units of [0, 1s], value 01 corresponds to 0, 5 sec.) CLM_TIMEOUT_RC_BTL initwert = 00 00 Comment = timeout for delayed open control of the bootlid (HKL) 1 unit = 1ms value range: 0... 5 sec Note: overall delay value is the sum of CLM TIMEOUT RC BTL (in CL-master) and RC TIME DELAY boat EYELID (component in remote control) – should be added for F020 when available in container: delay time to the electric opening of HK OPTIONS initwert = 00 00 - Comment = Timeout to active RC in Ms. Default is 0 ms for L7, 500 ms for L6 (Timeout to active RC in Ms. default is 0 ms for L7, 500 ms for L6) RC_TIME_DELAY_BOOTLID (RC TIME DELAY BOAT EYELID) wert_01 (value 01) = 05 Comment = timeout for delayed open control of the bootlid (HKL) 1 unit = 0, 1s value range: 0... 2s note: overall delay value is the sum of CLM TIMEOUT RC BTL (CL-master) and RC TIME DELAY boat EYELID (component in remote control) delay time to the electrically opening of HK - should be added for F020 when available in container: (building level > = 0703) + 316 tailgate LIFT OPTIONS wert_00 (value 00) = 00 - Comment = Verzögerung in Einheiten von [0,1s], wert_00 entspricht 0,0s. (Delay in units of [0, 1s], value 00 is equal to 0, 0 s.) wert_01 (value 01) = 05 - Comment = Verzögerung in Einheiten von [0,1s], wert_01 entspricht 0,5s. (Delay in units of [0, 1s], value 01 corresponds to 0, 5 sec.) |
CIWS655.00 |
01-04-2017, 05:04 AM | #19 |
Moon Parasite
655
Rep 1,336
Thanks guys, will give it a try and see what the result is. Even if it gets funky it can be flashed back to default.
01-05-2017, 04:49 AM | #20 |
Moon Parasite
655
Rep 1,336
Minor update, I had one chance at lunch yesterday to try it and edited Werte value to 10. (vs 05) and that pushed the trunk opening delay to something to between 3 and 4 seconds. I could stand there holding the button down for a good count to 3 and it would not open, repeated it several times. But about the time I counted to 4 it would pop open.
So some forward progress, and that by itself would solve any momentary presses occurring. But I would like to see if it will go longer. It's possible for some reason there's a "max" value / time and any larger setting won't make any difference. But I'd feel more comfortable with at least double that time.
01-05-2017, 02:03 PM | #21 | |
260
Rep 955
Yes.
It is possible there is a max value programmed in. Eg: If werte > X, set to X regardless. At least this was the case with my E series. Give "64" a shot. 64 = 100 in decimal. So that SHOULD give you 100 x 0.1 seconds. If it only gives you the 3-4 seconds you mentioned, then there is a max value programmed into the module. Quote:
01-05-2017, 06:17 PM | #22 | |
Moon Parasite
655
Rep 1,336
