M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > R888 235/35/19 x 265/30/19
      12-26-2016, 04:18 AM   #1
MYK
///MYK
MYK's Avatar
Kuwait
110
Drives: M2
I need a set of cheaper track tires, Michelin's are wearing really fast and cost a fortune. The r888 is my optimal choice buy only come in the above mentioned sizes. Any concerns/experience? Would they fit well/any rubbing etc? These will be used almost exclusively for track and driving from and to the track. Once I'm done (3-4 track days) I'll put the pilots back on the car.
      12-26-2016, 07:36 AM   #2
Twt
Twt's Avatar
633
Drives: 2017 M2
AD08R
I ran 888s for years on my Z06, they do tend to run a little large, but I would suggest that you stick to stock sizes ( maybe 255/275 as well ). I drive my M2 to and from the track in wet and dry so I am trying the Yoko Advan AD08R in stock sizes....you can also use the Bridgestone RE71. I consulted my tire guys and they say the Yokohama tires will be a well balanced track tire with good durability.
      12-26-2016, 08:54 AM   #3
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
Are you running dedicated track wheels or are you mounting track tires on stock wheels that you still need to drive to the track on?
The Bridgestone RE71R is excellent for autocross and for driving to and on track as an extreme summer tire. The Bridgestones are the fastest street tire available.
I've used the Advan Ad08 as well and they are much more suited for track use than the Michelin PSS, especially in hot weather when the michelins can chunk.
I would definitely stay with stock sizing or move up to 255/275 as opposed trying to put less tire on the car. That just won't end well. ( Note I don't think the Bridgestone 255 will fit up front so do research there)
If you want an easy wearing R type tire (like the R888) that you can actually drive to the track, you might check and see if the maxxis Victra is available. They wear like IRON. I can't kill them at the track and drive them on the street in between events because they are so indestructible. They aren't a fast tire but they are very reliable and consistent, which is great for lapping days.
      12-26-2016, 02:08 PM   #4
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
R888s are perfectly fine driving to and from the track on.
I'm an RA1 fan, but you'd have to (try) and run 275 18" square.
Speaking of which, are you using stock wheels? Is that why you're going w/19s?
If it were me, I'd be buying 18" track wheels. Cheaper tires, less weight/rotational inertia, etc.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-26-2016, 10:55 PM   #5
MYK
///MYK
MYK's Avatar
Kuwait
110
Drives: M2
Yes stock wheels. How about trofeo r in size 235/35/19 - 265/30/19?
Search this Thread:
Advanced Search
m2
