12-19-2016, 10:45 AM | #1 |
BimmerPost Supporting Vendor
1992
Rep 6,916
Detailer's Domain brings some life back to this Range Rover - Improper Washing
Got a call from a great customer of ours asking us to help him out with his dad's Range Rover. He told us that the car is in bad shape due to improper washing. I said really why don't you fix it yourself. He said no time and it's too far gone. I said you have everything to do it. He said you don't understand he washes it with bleach and various home cleaning goods. I said what! I told him if we do this you will have to teach him the right way to wash his RR, he said I can't promise you anything and this is a gift to him, what he does after he's on his own. Figured a quick run down on swirls removal and paint correction would help those on this article. What Is Car Paint Correction? AKA - swirl mark removal or machine polishing, paintwork correction is the reduction or removal of marks in the top layer of paint to produce a more refined finish. Paint correction can involves machine polishing of varying grades of cleanser, polish or compound. (can also be done by hand but in todays time and with todays finishing I would recommend machine polishing, preferably via an orbital polisher) Paint correction requires a high degree of skill and concentration, but done properly, it really can transform the look of a car by dealing with hard water marks, etching caused by bird droppings or bug and tar, swirl marks, scratches and fading or dull paint. Done professionally, paint correction is entirely safe and will not cause any issues for your paint. Why Consider Paint Correction? A vehicle’s paint has to deal with a lot of environmental challenges: Road grime and grit Bird muck, fly squash and tree sap Tar Water spots People brushing against the car with their clothing or bags Poor valeting techniques and/or products Poor machine or hand polishing techniques Auto car washes All of these things can leave the finish of a car looking less than perfect and at worst, dull, faded and covered in light scratches, swirls and other marring. Not only does this detract from your car's appearance but it ultimately reduces its value as well. For most, paint correction really can make a substantial difference and will completely remove or significantly reduce most marks. Not only this, but the resulting finish will have an amazing gloss, depth of reflection and slickness. Will swirls and paint issues reappear? New marks may appear over time (we can't stop future scratches), but with proper care you should be able to prolong them from reappearing. Paint Defects This project will: Remove all light haze swirl marks Remove any existing buffer trails/holograms Add an amazing shine and depth of reflection Restore most faded paint & reduce surface oxidation Create a stunning smooth/glossy finish Provide paint protection(3-6 months) Leave a slick feeling finish which is easier to clean This project will not: Remove the deepest swirl marks (circular scratches) Remove deep etching from bird muck, water, etc. Remove more than the very lightest of scratches Restore heavily faded paint or sub-clearcoat issues Improve the appearance of stone chipping Full list of products used during the new car process Exterior Nanolex Prewash Concentrate Nanolex Wheel Cleaner and Iron Remover Stoner's Tarminator Nanoskin Autoscrub Sponge Uber Clay Bar Nanolex Ultra Glass Sealant Nanolex Glass Cleaner Meguiar's M101 Meguiar's M205 Nanolex Tire and Trim Restorer Nanolex Spray Sealant Interior Nanolex Interior Cleaner Nanolex Textile and Leather Sealant Tools used: Metro Vac N Blo Car Vac Pro Series PRO-83BA CS Metro Air Force Blaster 8 hp Rupes LHR15 MKII Rupes LHR75E Meguiar's Microfiber Cutting Disc Uber Green Foam Pad Uber All Purpose MF Towels Uber Classic MF Towels Uber High Tech Glass Microfiber Towels Scangrip Multimatch Light Before shots Short on the prep shots but some foam shots and work flow shots Paint Correction Driver's Side Fender Before After Driver's Side Door Before After 50/50 shots The biggest difference was on the piano black trim Much much improved this is not done yet, we had to finish it down further. Final shots Last edited by Detailers Domain; 12-19-2016 at 12:45 PM.. |
12-20-2016, 01:38 PM | #2 |
123
Rep 326
Wow. That's awesome. Great job!
Some questions: I'm assuming paint correction cannot be done indefinitely? As there is only so much you can buff the paint down? I understand that a coating on the car can swirl. If a coating is put on top of the clear coat and becomes 'swirled', can the coating be removed and reapplied so that your paint and factory clear coat stay perfect indefinitely? Sorry if I butchered the explanation. |
12-20-2016, 08:15 PM | #3 |
1992
Rep 6,916
correct. you could ask your detailer to check the paint for you with a paint meter. from there you both can keep a record of how much is left. typically we check paint for customers and tell them how much we can do for them. I stop correcting paint at about 69-71 microns.
If you coat the car and it swirls you can spot polish the areas that are of concern. That being said you can compound or polish off your coating, and eventually into your clear coat /paint. |
Tags |
detailersdomain, detailing nj, nanolex, range rover |
