Mileage suddenly increased for more than 400k
12-18-2016, 03:56 PM | #1 |
Rep 7
Hi, mileage on the cluster suddenly increased. It was about 145k, but now it shows about 575xxx. The car is E90 330i 2005. Mechanic told me that problem is with the CAS, but after replacing CAS the problem wasnt solved. The CAS is installed and programmed with ISTA.
Mechanic tried another cluster (from another E90) just for few seconds to see mileage, and it was the same - 575xxx, with dot of course because that cluster is with another VIN.... Any idea? |
12-18-2016, 04:46 PM | #4 |
43
Rep 59
As if our cars don't depreciate enough
12-18-2016, 06:06 PM | #5 | |
Rep 7
Nobody changed any parts before...Every module is original that came with the car. |
12-18-2016, 08:34 PM | #6 | |
287
Rep 595
One of those is giving you a faulty reading. Do you have the mileage tamper indicator lit next to the mileage readout? It is located multiple places for backup/redundancy and to prevent one from from rolling the mileage back with too much ease. |
12-18-2016, 08:44 PM | #7 |
287
Rep 595
Just saw that you do have the tamper dot illuminated...
You've replaced the CAS. You say Inpa reports true milage in the DME. So I'd surmise your Kombi (instrument cluster) is the source of your problems. Here's the catch, and someone correct me if I'm wrong, Kombi from another vehicle is not directly swapable. This also applies to the DME. These two modules have lock timers that are triggered after xx minutes of operation. Past that point, they are no longer considered virgin and will not correctly sync with the other modules in the car. A new/virgin Kombi is likely the answer. Alternatively, I think a hack has been devised to restore old kombis to virgin status. It involves hooking up some tool (not inpa/rheingold/dis) to the Kombi and erasing info on one of the chips. Search about BMW M5/m3 cluster swaps to get more info. |
12-19-2016, 01:48 AM | #8 |
Spaceship Man Bad
1676
Rep 251
Holy shit and I thought my TDI deprecated fast... 400K of driving in a day that's gotta hurt the KBB, I definitely wouldn't be buying a car that was run at 17,000mph for a whole day
12-19-2016, 05:12 AM | #9 | |
Rep 7
- there is NO tamper dot on the (original) cluster - temper dot shown only on the cluster from another car when we tried it for few seconds just to see what mileage will be shown - nobody tried to hack anything...there is no reason for that at all!!! So, all modules are original and there is NO tamper dot on the cluster with old or new CAS...just a wrong mileage. Kombi/cluster from another E90 tried just to see what is gonna happen...it was for few secs. Why that cluster shows wrong mileage too? From which module it reads that mileage? If we install a brand new cluster/kombi, maybe that cluster will read that, the same, wrong mileage? Last edited by draganp; 12-19-2016 at 05:18 AM.. |
12-19-2016, 05:53 AM | #10 | |
287
Rep 595
In your particular case, it is obvious that a module has malfunctioned and is now reporting an erroneous mileage reading. To fix the problem, we first need to know which module is reading high (400k). For that, we need to read the data from each module. You seem to have verified the DME is reporting correctly. You also replaced CAS, so it should be fine. Kombi is remaining... But you swapped in a new used Kombi and still get 400k. Strange that it, too, reads high. Something is reporting 400k to Kombi. Maybe the mileage is stored in additional modules we haven't covered, though I thought it was only in 3 places. Perhaps when you put the new CAS in with the original Kombi, it updated back too 400k. And when you swapped the trial Kombi in, it received the 400k reading from your new CAS, which got the reading from your original Kombi. I don't know,I'm just speculating now... I do know that Kombi will display the highest recorded mileage, info taken from the units it is stored in. Can inpa read the mileage info from the Kombi, from the CAS???? |
12-19-2016, 06:43 AM | #11 | |
Rep 7
We couldnt find a way to read mileage from the Kombi and CAS. Actually on the first screen you can see all car details including mileage, and that mileage is read from kombi. We tried it without kombi at all and there wasnt mileage, so the very first screen reads mileage from kombi. The mileage there is in kilometers, not in miles, so it shows more than 920k km |
12-19-2016, 12:22 PM | #12 | |
287
Rep 595
Just in case, have a look at this: http://blog.wobd2.com/2015/10/30/solved-bmw-e60-keys-do-not-update-mileage/ |
12-19-2016, 12:34 PM | #13 | |
287
Rep 595
Look at the jpg image at the bottom of the thread here: http://www.bimmerfest.com/forums/showthread.php?t=904143 I'll upload the image just in case the linked site isn't allowed here. It is from a program called BMW Dash, and it shows the current stored mileage value. I'm still thinking about what all of this means (if anything), in your situation... #givemeaminute |
12-20-2016, 06:32 PM | #14 |
Rep 7
I found that program BMW dash and a screenshot on the eBay. Here is the link https://goo.gl/yKdBL9
Btw, we found a file with the fault from that service two months ago. It is XPS file (ISTA prints to this file type) and there the mileage was 237047 km, but cluster was showing 570671 (miles). So, back then mileage on the cluster was different than ISTA read?? I have a photo of a cluster and XPS file with some fault, from the same date. Few days ago: - ISTA read 921753 km, but cluster showed 572750, and it is OK (921753 km = 572750 miles). - DME showed 153000 (probably miles?) As you can see according cluster the difference is 2079 miles and it is probably correct. The mileage that ISTA read 2 months ago was 237047 km (or 147294 miles), but DME now shows 153000 and 153000-147294=5706 miles... From which module ISTA read that mileage two months ago I dont know. I know that few days ago we tried to connect car with cluster disconnected and ISTA showed 0 km (because cluster/kombi was disconnected). Now...nothing makes sense |
09-24-2018, 02:14 PM | #16 |
Rep 7
09-24-2018, 04:16 PM | #17 |
4277
Rep 9,209
You could just change the numbers to desired value. Won't be more than replacing the parts. Yes, I'm from Macedonia.
Tags |
mileage e90 |
