OSS/ONEighty style "blackout" LED headlights Adaptive
12-18-2016, 02:20 PM | #1 |
612
Rep 1,326
I'm selling a set of OSS/ONEighty style headlights with:
Both headlights are missing the bottom mounting tab near the corner light, but will mount absolutely fine and secure using the remaining lower bracket and top 2 brackets. The passenger headlight has been properly repaired in the back of the housing, and around the adaptive module area, both of which cannot be seen when mounted. The passenger headlight is also missing the top adjustment knob for horizontal adjustment but can still be adjusted using the rear adjustment knob. Typical wear/rock chips on the lenses for 50k miles, absolutely no gashes/cracks. Asking SOLD paypal'd and shipped for the set and I will NOT require your stocks in return. You'll need to transfer over your ballast and adaptive modules but it is easy to do (plug and play). I have itrader feedback of 40 on m3forum under the same username from my e46 M3 days. Located in Fremont, CA. Passenger headlight: Passenger headlight: Passenger headlight: Driver side headlight: Driver side headlight: Driver side headlight: Missing lower bracket near corner light on both lights: Passenger light missing top adjustment knob but can still be easily adjusted via rear adjustment knob: Passenger light rear housing properly repaired/sealed from the inside and outside: Quick test fitting on the car: Extremely bright when on:
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
