Completely overwhelmed by the wheel/shock/spring search :(
12-13-2016, 11:23 PM | #1 |
73
Rep 463
Hi everyone,
I'm trying to switch out my current sport package 2007 E90 335i to soften it up. Currently it has 225/40/R18 fronts and 255/35/R18 rears, plus Koni FSD shocks. Everything else is stock. I want to switch the shocks + springs to non-sport OEM... where should I be buying these parts? I was told that the Bilstein B4 is exactly the same as stock, but Tirerack says it's 10% stiffer than stock... and I think "stock" there is referring to "sport package stock". Also, I was looking at potentially getting some 17" wheels, but everything I saw on Tirerack was pretty expensive. Where should I be looking? Finally, there's the question of aspect ratio. One forum member suggested that I could simply stay with my 18" wheels, but just widen the aspect of my tires, going to 225/45/R18 + 255/40/R18. I love that idea... it will have the same amount of tire cushion as the 17" setup, so will it be just as comfy as 225/45/R17 + 225/40/R17? Can I go as far as trying 225/50/R17 + 255/45/R17??? I figure that would be pretty comfy! Sorry for all the questions, and thank you for your advice. Last edited by Drivaar; 12-13-2016 at 11:32 PM.. |
12-14-2016, 09:29 AM | #4 |
2341
Rep 3,539
Regarding tires:
---------------------------------------------------------------------- Your current setup Fronts 225/40/R18 Sidewall height = 40% of 225 = 90mm Rears 255/35/R18 Sidewall height = 35% of 255 = 89.25mm Option 1 Front 225/45/R18 Sidewall height = 45% of 225 = 101.25mm Rear 255/40/R18 Sidewall height = 40% of 255 = 102mm Option 2 Front 225/45/R17 Sidewall height = 45% of 225 = 101mm Rear 225/40/R17 Sidewall height = 40% of 225 = 90mm This option is not favorable as sidewalls are not close to each other and your speedometer will read wrong. Not sure if you meant 255/40/17 which would be a more favorable option with 102mm sidewall. ---------------------------------------------------------------------- So what can we conclude from this is that, by increasing the tire sidewall percentage number, sidewall height is increased. You will need to ensure that you have enough clearance for increased sidewall height (no rubbing). However, changing the wheel diameter will not affect sidewall height. What wheel diameter will affect is the height of the car in relation to how low it sits to the ground. So with that said, if there is potential for rubbing with 225/45/18 and 255/40/18 then in order to maintain that same desired sidewall height you would need to drop down in wheel diameter to 17". That would give you 1" clearance from the overall tire diameter while maintaining equilateral sidewall height. Last edited by Wolf 335; 12-14-2016 at 02:07 PM.. |
12-14-2016, 06:35 PM | #5 |
73
Rep 463
Thank you so much, Wolf 335. After a lot of thought, and a nice conversation with a great guy at TireRack, I ended up with 225/45/R17 + 245/40/R17, which should give me nice comfort while allowing the use of 17x8 wheels both in front and back to match.
12-15-2016, 08:03 AM | #6 |
2341
Rep 3,539
I think that's a good choice for comfort ride
12-15-2016, 09:33 AM | #7 |
Guest
Rep n/a
Drives:
I think you first need to be realistic when setting expectations as it relates to "comfort." What is your goal here: Lincoln Town Car type comfort or just having a car that's composed enough to not have the suspension completely crash over every bump like it does stock?
Sometimes peeps will drive and Audi or a Lexus then jump back into their E9x and be like "I wanna make my car ride like that" and that typically results in setting a goal that is impossible to achieve. Furthermore, just adding taller tires could end up being a step in the wrong direction; instead of creating a more comfortable ride, you could end up with a floppy wet noodle version of what you already had. |
VTECaddict481.00 |
12-15-2016, 10:38 AM | #8 |
3441
Rep 79,211
First question is what kind of tires are you on currently and are they run flat?
Also have you considered Koni Orange? They are OEM Equivalent and you can select between non sport and sport options. Last edited by Jeff@TopGearSolutions; 12-15-2016 at 10:48 AM.. |
12-18-2016, 01:38 AM | #9 | |
Where'd my VTEC go?
481
Rep 6,067
If you want something that rides like a Camry, you need to get a Camry. Or a non-sport F30.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
