12-12-2016, 02:59 AM | #1 |
371
Rep 183
M5 gets a switchable AWD ?!
Featured on BIMMERPOST.com source: http://www.bimmertoday.de/2016/12/12...uf-knopfdruck/ The complete article translated: "The change of the BMW M5 F90 to four-wheel drive is supposed to make the power sedan from Garching even more appealing, but some customers are annoyed by the absence of the rear wheel drive, but there is good news for this clientele, because if our information is correct The new BMW M5 F90 at the push of a button: Depending on the driving mode, the driver can decide whether he wants to distribute the power of the V8-Biturbo to all four wheels or prefer the full power on the rear axle. We assume that the corresponding mode with pure rear wheel drive can also be stored on one of the steering wheel buttons. If you want to be particularly dynamic, you can activate the driving mode for maximum driving pleasure with two short thumb movements and also enjoy the BMW M5 F90 with rear-wheel drive. The option of rear-wheel drive at the push of a button is designed to take the wind out of the sails that make the new BMW M5 F90 less exciting than its predecessor due to its standard all-wheel drive. In many situations, however, the four driven wheels will offer advantages, not least in terms of acceleration. On dry asphalt, a maximum of 3.5 seconds will pass before the three-digit speeds are reached. Apart from this, the all-wheel drive naturally offers great traction advantages on slippery ground, which is to open up new customers in the alpine area and the North American Snow Belt. The power sedan is powered by a further developed V8-Biturbo with a displacement of 4.4 liters, which is expected to press almost 600 hp on the crankshaft at the beginning of the market in 2018. Later variants such as the BMW M5 CS will continue to turn at the power screw and underpin the special wheel of the BMW M5 as a sports car in the business dress. In order to be able to look even better on stretches with tight corners, the M GmbH has also parted with the weight of the BMW M5 F90. The top model of the new 5 Series G30 not only benefits from all lightweight construction measures of the large series, but also adds additional elements with elements such as the standard carbon roof. On the bottom line, the M5 should bring a few kilograms less than the predecessor despite the more complex drive train with all-wheel drive and more extensive series equipment. It goes without saying that the experts at M GmbH also do a lot of fine work on the chassis and thus also want to improve performance." |
12-17-2016, 12:40 PM | #2 |
1849
Rep 2,553
This defeats the purpose entirely. For me, AWD is stupid for a performance car because it ADDS weight. Provided the weight distribution is good and the AWD is rear biased, it won't under steer. A RWD setting just means your car is rwd with a stupid amount of weight added for no reason. I mean honestly...
STR8-6IX536.00 |
12-17-2016, 12:56 PM | #3 |
210
Rep 389
I actually think that's a great move. Give the driver the option and make it the most useable daily performance vehicle available
X5 40d M F15 - July 2018 - Space Grey
Mini JCW F56 - June 2018 - Rebel Green Previous: 340i M F31 2016-18, 2015-16 435i M F32, 2013-15 330d M F30, 2011-13 Mercedes C250, 2008-11 320i E92 |
Bosozoku693.50 YungDro1088.00 AtlantaDude128.00 Refujeet262.50 MilehighM3909.50 antzcrashing1874.50 DD335i116.00 iamdabest1127.50 |
12-17-2016, 01:05 PM | #4 | |
44
Rep 34
But, if all of a sudden you had the ability to feel semi-confident in inclement conditions, you might be convinced to go throw down out there. It allows you to use your badass M5 for a longer period of time anyway, so where's the harm in that? |
12-17-2016, 01:11 PM | #5 | |
513
Rep 985
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
12-17-2016, 01:15 PM | #6 | |
180
Rep 326
Drives: 2021 X5M
To the other poster above...... I like this new strategy. AWD is great for faster sprints to 60 or 100. Also will help pull the car much FASTER around the track. Witness the 918's performance on track and know the AWD was instrumental to beat the P1 and LaFerrari all which had MORE horsepower and were lighter! AWD is a big benefit in all aspects. Don't let the small amount of weight fool you as that is a very worthwhile tradeoff unless you prefer to go slower |
12-17-2016, 01:30 PM | #7 | ||
1849
Rep 2,553
12-17-2016, 01:32 PM | #8 | ||
1849
Rep 2,553
Provide two different models one with RWD one with AWD. |
12-17-2016, 01:43 PM | #9 | |
44
Rep 34
12-17-2016, 01:44 PM | #10 |
11
Rep 29
My local stealer told me this months ago. Posted it somewhere on the forums. Makes complete sense with the huge torque at low revs that modern turbo engines produce. I've just read Januaries Car magazine (UK) about the new AMG E63 S which also 4 wheel drive and they loved it. It the same issue, a new mid range 5 series beat the equivalent E series, so looking good for the M5.
12-17-2016, 01:44 PM | #11 |
3540
Rep 10,327
This makes perfect sense and M division alluded to AWD years ago. Hell the SAV M's have always been AWD. Besides today's M cars are making too much low end torque for RWD (ex F8x).
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
Bosozoku693.50 |
12-17-2016, 01:46 PM | #12 |
1912
Rep 4,128
Drives: M235i & G30 540i
The people whining about AWD in the new M5 fail to fully grasp that BMW is being left behind due to all of the competition putting down so much more power to the wheels because of AWD. You want BMW to stay RWD but that would mean not being able to fully compete with everything else. If this option to be both AWD and RWD is real, it would mean the best of both worlds and you will have to live with the extra weight.
Get with the program or get left behind.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
12-17-2016, 01:51 PM | #13 | |
861
Rep 349
12-17-2016, 01:52 PM | #14 |
2252
Rep 3,622
In other words: DRIFT MODE!
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
12-17-2016, 02:04 PM | #15 | |
2290
Rep 4,447
12-17-2016, 02:14 PM | #16 | |
17
Rep 50
Sounds like a winner, already really like the look of the new 5 series, looking forward to seeing what the M5 brings. |
12-17-2016, 02:24 PM | #17 | |
71
Rep 266
Bosozoku693.50 |
12-17-2016, 02:43 PM | #19 |
1088
Rep 1,149
thread closed....
Bosozoku693.50 ron_jeremy513.00 |
12-17-2016, 02:52 PM | #20 | |
Almost completely sane
694
Rep 1,080
It's a featherweight at 3,417 lb. Less than an M2. Because you're not hauling around all those modern luxury goods. Let's see now. The outgoing F10 M5 weighs about 4,288 lb. Here's the math: 4,288 - 3,417 = 871 lb. You'd be saving 871 lb. and probably a lot of cash as well. Note: The G-generation M5 might weigh less than the F11, but will probably cost more. Source (for M5 model weights): https://en.wikipedia.org/wiki/BMW_M5...2.80.931988.29
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
12-17-2016, 03:15 PM | #21 | ||
5849
Rep 10,229
mvigod179.50 |
