Horn doesn't work when car is off
12-11-2016, 03:12 AM | #1 |
12
Rep 47
When I sold my X5 E53 and got my E91 LCI 320d, I noticed something annoying about it: when you press the start/stop button once, windows go up and down, iDrive works, you can flash the high beams, indicators work? but no horn. In this situation (first turn of the key), the horn would honk on the X5.
In the 3 Series, I can only honk with the ignition on (another press of the start/stop button) or obviously with the engine running. Most of the time when I'm sitting in my car I only press the engine start/stop button once, because I want to listen to music. However, the other day, someone drove past me and hit my rear view mirror with his. Thankfully I could put it back in place and it didn't have a scratch (kudos to BMW for that) but I couldn't honk my horn to let the guy know. He just left. Is there any way to make the horn work without ignition? Please tell me if you have a solution. |
12-11-2016, 06:02 AM | #2 |
17317
Rep 18,738
I doubt there is a way to change it, but maybe with the newer cars it can be programmed. I'd throw this question out in the Coding subforum. Every BMW (4 in total) I've ever owned has operated this way.
12-12-2016, 04:56 PM | #3 |
226
Rep 553
I had 2 08 328's which I'm pretty sure the horn worked without the ignition. My 07 335 does not. I thought it was something changed in 08, but you have a 2012 so...
12-13-2016, 02:16 AM | #4 |
12
Rep 47
12-14-2016, 07:52 PM | #6 |
453
Rep 2,973
I've had lots of BMWs and the horn only works with the car on.
Multiple generation M3s, 530i and my 335 all work the same way.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
12-15-2016, 03:01 PM | #7 |
536
Rep 2,825
why do you need the horn when your car is off? why is this so concerning that you just had to make a thread about it? my horn did not work while my car was off until i cycled the ignition on and off.
12-15-2016, 10:16 PM | #8 |
93
Rep 343
Sometimes to save gas I'll turn the car off on a long downhill stretch. It's good to have the horn in case I blow through a stop sign or a school zone.
dannyhavok132.50 |
12-15-2016, 11:16 PM | #9 | |
228
Rep 1,045
The horns are supplied by the JBE, so the trick is to get the JBE to activate the horn circuit. It seems that the horn might need some rewiring, to come off Terminal 15F control and be put onto Terminal 30B control. Just a first pass guess, that it is not simply coding but overcoming the way the car Power Management functions. |
12-16-2016, 08:50 AM | #10 |
Rep 19
12-16-2016, 03:12 PM | #12 |
armchair enthusiast
221
Rep 1,019
I've noticed my brake lights don't work with ignition off in either my '07 E92 or '02 E46.
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop '93 850Ci Oxford Green/Parchment, auto '71 Buick Riviera, 455 V8 land yacht |
12-20-2016, 10:36 PM | #13 |
Rep 284
In a word, safety. I was backed into when I had my '06 just after parking and shutting the car off. Very low speed in that case and fortunately no apparent damage, but it probably could have been avoided altogether if BMW hadn't decided that the horn shouldn't work when the ignition was turned off.
12-20-2016, 11:35 PM | #14 | |
536
Rep 2,825
