Rear wheel rubbing
12-10-2016, 09:28 PM | #1 |
Rep 10
Rear wheel rubbing
My ride is lowered 30mm. I just put 19" wheels on. The tyres are 265/30 - too wide i know. The passenger side doesn't rub but the driver side does. The other day was changing the sensor and noticed the spring upper pad had completely busted. I pulled it out and it was all dried up.
I was going to get the fender rolled, but if only one side is rubbing, I'm thinking it could be the now-missing upper pad (part 9 on the attached image). Could the missing spring pad be causing the spring to collapse too much? |
12-10-2016, 10:47 PM | #2 |
Rep 10
12-11-2016, 12:40 PM | #3 |
87
Rep 471
I'd replace upper pads on both sides before rolling the fenders. However, rolling will give you more clearance.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
12-11-2016, 01:57 PM | #4 |
Rep 6
How many miles are on your car? I get the same rubbing on only the driver side and have been planning to roll the fenders but maybe I'm having the same problem. I have the stock suspension setup tho on my E92 with only 46K so i hope its still holding up.
12-11-2016, 06:37 PM | #5 |
Retired US Army/Police Officer
30
Rep 161
Drives: F10 M-Sport, E-92
I run the same size on mine and no rub.
318IS-330IC-E90-E92 328i F10 535i M
