12-08-2016, 06:39 AM | #1 |
274
Rep 2,774
No tpms wheels on to a car with tpms
Quick question. Are they compatible? I've rented an f31 335d to fill a gap between cars and have my winters from my old 335d that I can use if needed but they don't have tpms
12-08-2016, 07:05 AM | #2 |
258
Rep 3,815
If you dont have the valve sesnors you will basically just get an error and a yellow light on dash saying you have a fault on the system. If you can live with the yellow dash light than its fine.
When you refit the TPMS wheels just do a tyre pressure reset and the system once you go for a drive come back on line
F30 335i M Sport - now departed
pjs274.00 |
12-08-2016, 07:06 AM | #3 |
1397
Rep 8,083
You will get a warning and an annoying bong unless you either fit TPMS valves or code the car so that it uses the ABS sensors to measure rotational speed to detect deflation.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
pjs274.00 |
12-08-2016, 09:52 AM | #6 |
218
Rep 492
How would you know whether a car has TPMS or not?
It's not something I've ever seen on an options list. Do all F3x 3/4-series come with it?
____________________
Current: Macan GTS Previous: 440i GC, M135i, E60 M5, Z1, 330d, 135i, Alfa 156 GTA, Mercedes 500E, Audi S3, Audi A3 quattro, VW Golf GTI 16v |
12-08-2016, 10:07 AM | #7 |
1397
Rep 8,083
From mid 2014 they do. You can tell from the outside by the tyre valves having metal stems and from the inside individual tyre pressures on the iDrive.
Ian
12-08-2016, 10:10 AM | #8 |
218
Rep 492
Ok, thanks
12-08-2016, 10:44 AM | #10 |
224
Rep 3,016
I've just been through this and was initially going to live with the light (only one bong on start-up) over the winter months, until I was told that some form of TPMS, either direct pressure sensing or ABS sensor based, is mandatory on all post 2014 cars.
Obviously there are insurance implications so I then met up with a local coding guru who coded my 2016 car from direct pressure sensing to ABS detected but I knew that I'd have to reverse the procedure when refitting my summer wheel tyre set so I ended up fitting sensors to my winter wheels and reverted the coding accordingly. Got a set of genuine BMW/Huf sensors on eBay for £125 (dealer wanted £320!) and everything's fine. |
duvetdo98.00 |
12-08-2016, 02:43 PM | #11 | |
98
Rep 247
https://www.ebay.co.uk/itm/122250246469 Need to buy some for my winters going on next week. |
12-08-2016, 03:09 PM | #12 | |
3481
Rep 3,691
However did we exist before TPMS.....? |
12-09-2016, 04:17 AM | #13 | |
224
Rep 3,016
duvetdo98.00 |
12-09-2016, 04:25 AM | #14 | |
224
Rep 3,016
I was informed that TPMS has been a requirement on all cars manufactured since 2014 and that was a major deciding factor for me personally. Many thanks for your clarification regarding blow-out prevention, I was under the impression that they automatically reinflated the tyre in an emergency - must have been misinformed... |
12-09-2016, 03:56 PM | #15 |
3481
Rep 3,691
TPMS just warns you when tyre pressure drops below a preset value, to let you know a tyre may be punctured. There's no reinflation, but the stiffness of the sidewalls makes sure the tyre doesn't disintegrate if driven flat for a limited distance.
12-10-2016, 05:10 AM | #16 | |
224
Rep 3,016
Be assured that my previous reply was nothing less than 100% tongue-in-cheek. |
12-10-2016, 05:49 AM | #17 | |
224
Rep 3,016
The installation torque (4Nm) is quite low and it must be done with a torque wrench. After the initial tightening the collar breaks through the friction lock and I was surprised by how much further it turned as the seal flattened out, before the final torque was established. Huf instructions here: http://www.intellisens.com/menue/downloads/ |
12-10-2016, 03:21 PM | #18 | ||
98
Rep 247
12-10-2016, 05:50 PM | #19 |
3481
Rep 3,691
12-12-2016, 10:02 AM | #20 |
814
Rep 2,176
My daughter's got a new 118d on order which will come with the latest TPMS valves on it, obviously! We know her current winter wheels and tyres will fit the new car but they are steel wheels with plastic covers and have the ordinary old type tyre valves fitted. So was interested to read what has been said on this thread regarding the warning light on all the time on the dashboard etc.
Just made some enquiries with the local dealer and to put the radio valves on to the winters on her car will cost over £250 !!! So following some of you other guys I've been raking around on e-bay but can only find ones with the part number ending in 539, apparently on the steel wheels the part number is different ending in 209 or something like that, anyway they are a slightly different valve for steel wheels.....can anybody confirm/clarify/help please?? |
12-12-2016, 10:08 AM | #21 |
224
Rep 3,016
If the spare winter tyres are the same size as the new car it might be more cost effective to seasonally rotate the tyres on the new rims.
Some dealers offer a 'hotel' service to store the tyres you're not using. |
