12-07-2016, 03:18 PM | #1 |
23
Rep 91
Drives: M235i & X1 2.0d
Need help with wiring from backup camera control unit
Bought camera, control unit and harness from a wrecked car and need help with how to wire the harness from the control unit up to the front. Searched but not been able to find info on this. Anyone done this or able to help?
12-08-2016, 12:08 PM | #2 |
191
Rep 314
The control unit's original mounting location is in the driver footwell on the left. Two CAN wires go to your FEM_BODY in the passenger footwell, three FBAS video wires go on the quadlock to your headunit, one +12V wire goes to the camera's assigned fuse in the rear fuse box and a ground wire which you can tap from anywhere such as the footwell lamp.
If you want the exact pin numbers you can PM your VIN so I can check for you since some of the pin numbers differ between model years. |
12-08-2016, 04:56 PM | #3 | |
23
Rep 91
12-09-2016, 08:57 AM | #4 |
191
Rep 314
On the plug that goes into the control unit:
Pin 1 ground Pin 2 goes to pin 21 on quadlock Pin 3 goes to pin 24 on quadlock Pin 4 goes to pin 23 on quadlock Pin 5 goes to pin 52 on connector A173*8B in the FEM Pin 6 goes to pin 51 on connector A173*8B in the FEM Pin 7 goes to fuse F154 in the rear fuse box Last edited by Gabrola; 12-09-2016 at 09:05 AM.. |
12-10-2016, 07:30 AM | #5 | |
23
Rep 91
