12-06-2016, 02:30 AM | #1 |
680
Rep 2,444
Drives: 2018 630iGT sport
Considering a remap
So I've had the car over a year now, and I'm getting seriously tempted to remap it, as the output gains are impressive for relatively little outlay.
My only concern is the warranty. Has anyone else had theirs remapped and run into any issues regarding warranty work when required? Obviously the map can be removed/reloaded if required, but that's a bit of a faff. |
12-06-2016, 02:46 AM | #2 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
There's an element of risk with pretty much all tuning/modding so my advice would be to manage that risk as best you can. Choose your tuner carefully. Maps can be removed/reloaded IF you have the opportunity. If your motor grenades on the M6 and is recovered by BMW you won't have that opportunity. So you might want to consider how much risk you want to take on and whether you can afford that risk as well as the purchase price of the map.
hyakuhei50.00 |
12-06-2016, 02:57 AM | #3 |
680
Rep 2,444
I hear you Lorcan.
I didn't remap my e92 335 as it had the N54 lump, and I was already concerned enough with that blowing a foo-foo valve. I suppose in my head, the F32 is newer, a lot less miles on it so chance of something shitting itself should theoretically be significantly lower, and also being the N55 engine, not prone to the same turbo problems of the earlier engine. |
12-06-2016, 03:20 AM | #4 |
6422
Rep 8,501
It depends on the gains that you want to achieve, and what's available of course.
MPPK maintains the full BMW warranty, but is at the conservative end of the spectrum. ECU piggyback probably the most convenient for install/removal, but be careful choosing one which doesn't have a crude method of operation i.e. simply increasing fuel rail pressure. Multi channel systems should be a better bet. Full remap often considered to the the 'best' overall, and the more reputable tuners may provide a warranty. Engines and gearboxes do have limits and they also have headroom to make safe gains. A stock engine/gearbox which has to endure launch control on a frequent basis is more likely to suffer premature wear or failure compared to a tuned car which is treated with some mechanical sympathy.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
12-06-2016, 03:26 AM | #5 |
8567
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
I had my remap done by DMS and it's had a bit of warranty work carried out since then and the map was never detected. That warranty work included replacing the EGR system, so an engine issue.
I think one of the dealers suspected a remap (but never asked me), as they re-installed the engine management system which wiped the map, but failed to notice the cracked EGR pipe and the fault remained. I had the map re-installed by DMS and went to a different dealer who immediately said the EGR system needed changed. Again, they didn't detect the remap. So, what I'm saying is, get the right re-mapper and I don't think you need worry too much.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
Lorcan3609.00 |
12-06-2016, 04:36 AM | #6 | |
Live for today tomorrow never comes
1989
Rep 9,498
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
12-06-2016, 05:01 AM | #7 | |
355
Rep 1,846
12-06-2016, 05:21 AM | #8 |
978
Rep 2,069
And if it does go bang, so what?
A professional map is not detectable by dealer diagnostic. They would have to drive the car to suspect it's been done. Can't do that if it won't run. The specific ECU parameters would need analysing, with a direct comparison of those parameters with a 'standard' ECU. This is very specialised stuff for a manufacturer to undertake. I say this from experience. My mapped E90 developed an ECU fault. Lots of extended diagnosis done, including data being sent to Germany. ECU was replaced under warranty, no questions ever asked.
/// BM3 + M-Power ///
12-06-2016, 05:48 AM | #9 |
8567
Rep 19,982
I had an intermittent engine warning light, and the occasional smell of exhaust fumes under the bonnet.
12-06-2016, 01:04 PM | #10 | |
3533
Rep 11,292
My car is going in again for something in a couple of days and if I get to chat with a technician, I'll ask him too. Obviously they won't go looking for it unless your engine goes bang, otherwise I guess they won't give a stuff. Things have moved on a bit since the E90 days.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
12-06-2016, 01:07 PM | #11 | |
8567
Rep 19,982
12-06-2016, 01:16 PM | #12 | |
3533
Rep 11,292
But did they actually tell you they looked for a remap and said they found nothing? If they had no reason to look, they won't find one. But if they did look.......?
12-06-2016, 01:21 PM | #13 | |
8567
Rep 19,982
The second place I was standing with the technician as he connected it up and he said that diagnostics check would throw up a warning if it detected a remap, and that it would also state which parts of the cars where warranty was voided at the same time. So the very act of running the diagnostics includes the car systems being checked for a remap as I understood it. I asked if they do detect them and he said yes they do sometimes, though usually on older cars where the warranty is over anyway so it doesn't matter in that regard. So, that does suggest that not all remappers are as able to cover their tracks as others.
12-06-2016, 01:24 PM | #14 | |
3533
Rep 11,292
I'll be looking for a dms map then, if I ever get mine done.
12-06-2016, 04:40 PM | #15 | ||
978
Rep 2,069
My cars just had a dealer major service. Map undetected despite me asking the technician to try & find it. He, nor any of the BMW wizardry found anything. He would have relished to find it as well, to 'get one over on his dad'... Me!
12-06-2016, 05:31 PM | #16 | |
3533
Rep 11,292
12-06-2016, 05:35 PM | #17 | ||
978
Rep 2,069
