EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      12-05-2016, 03:56 PM   #1
SSR Performance
BimmerPost Supporting Vendor
SSR Performance's Avatar
635
Drives: S55 -F80 / N54 -135i / N55-535
Smile Emmanuele Design M3 / M4 Lowering Springs Special! ($425 INSTALLED) - Limited Time
Starting today at SSR Performance, we will be offering Emmanuele Design lowering springs for your M3 / M4 for the unbeatable price of
$425 INSTALLED!
Contact us to make an appointment today! (800) 438-2808 or info@SSR-Performance.com
SSR Performance is excited to announce our collaboration with Emmanuele Design to bring you the best in both ride quality and an unheard of price to have your car lowered today! When it comes to ride quality and looks, Emanuele Design brings you the best of both worlds. With plenty of customer testimonials explaining how similar the ride feels to stock, have no fear that you will sacrificing function for form. Here is a little bit of information about the springs straight from Emmanuele Design:
As with our other lowering spring options, the goal with this offering was to lower the M3 / M4 by a tasteful amount while keeping ride quality the same or better than stock. After multiple prototypes and valuable user feedback, we believe that we met our goal.
Specifications for our lowering springs are:
Front Lowering: 1.3"
Rear Lowering: 0.9"
Stock Front Rate: 186 lb./in.
eMMOTION Front Rate: 194 lb./in.
Stock Rear Rate: 608 lb./in.
eMMOTION Rear Rate: 645 lb./in.
Our lowering springs are specifically designed to utilize the factory dampers. They are fully compatible with both standard as well as adaptive suspension. Each spring is made in the USA to our unique specifications for rates and geometries. The springs are made of high tensile chrome silicon and each unit is shot peened, pre-set and 100% tested to ensure all the critical dimensions and rate/loads are within tolerance. The springs are then powder coated with a stealth black finish for an OEM appearance.
Are these springs compatible with adaptive ride control?
Yes, these springs are compatible with adaptive ride control. They pair extremely well with the adjustable dampening, as they maintain the distinct ride characteristics between the different modes.
Are these springs okay for a daily driver?
Yes, these springs were specifically designed for daily driven vehicles. They were designed to maintain the factory ride quality.
Will lowering springs cause my factory shocks and struts to wear out prematurely?
Our springs are a linear rate design, similar to the OEM units. As such, they will not cause additional wear on the shocks and struts. The spring heights are also designed to stay within the travel range of the factory shocks and struts to ensure longevity of the factory components.
Will there be any added noise with these springs?
No, as we use a linear design with no dead coils, there will be no added noise over a stock spring. These springs are designed to be a direct replacement for the factory units, with no need to change any other components.
$425 INSTALLED!
Before
After
Before
After
You won't want to miss out on this limited time deal! Please call us or email us for any questions that you may have! We are more than happy to answer them
      12-05-2016, 05:59 PM   #2
YangEnterprise
YangEnterprise's Avatar
216
Drives: 16 BMW M4 - JAVA GREEN
Great price! Springs look great. SSR Performance knocked it out of the park again as usual. Keep it up guys!
      12-05-2016, 09:35 PM   #3
SSR Performance
635
Thank you sir!
      12-05-2016, 10:53 PM   #4
YARBMAN
11
Drives: YuGA
I have a few questions for mr emanuele.
Question 1-will Emanuele personally install my springs
Question 2-if I bring my own emanuele springs is install free?
Question 3-what are the horsepower gains, and do I get a dyno run to back up claims?!
Please advise
      12-06-2016, 12:08 AM   #5
SSR Performance
635
Smile
Please advise
1 - Unfortunately Mr Emmanuele is hibernating for the winter
2 - If you bring your own springs we will be happy to remove $1 from our original price of $375
3- We haven't dyno'd post-install yet. We will update you immediately as soon as we have any updates
      12-23-2016, 09:43 AM   #6
SSR Performance
635
Holiday Bump!!
      03-28-2017, 04:36 PM   #7
SSR Performance
635
BUMP!
      04-02-2017, 07:34 PM   #8
my335i
my335i's Avatar
Philippines
90
Drives: f80 m3
interested but having issue pming you...
      04-03-2017, 09:37 AM   #9
SSR Performance
635
PM sent brotha!
Tags
discount, f8x, lowering, m3m4, springs
f80post
