Automatic Trans Owners With 60K+ Miles
12-05-2016, 03:05 PM | #1 |
536
Rep 2,825
Hi all, just wanted to share some information regarding our Zf transmissions and the important fluid change which I had done today. I have recently noticed after 100,000km that shift quality started to gradually degrade. I didnt think much of it until my transmission started acting up fairly seriously about once or twice a month. it would hesitate, and then jump into D causing the whole car to shudder quite violently, it felt bad. on top of this, every shift would jerk the car around and it honestly felt like the transmission was damaging itself.. So I finally went and got the fluid changed today (have 111,500KM on the clock) the fluid was quite dark, a very dark brown. after changing the fluid, initial impressions were very positive. initial throttle tip-in improved noticeably and the drivetrain felt alot more smooth and refined especially when revving out. shifts were much quicker and smoother then before along with much less torque converter lag then i remember from before. Even if your transmission is operating fine, if you are nearing this mileage I highly recommend you have your fluid changed simply as preventative maintenance to have your transmission operating healthy for as long as possible. on a side note, you will need to replace your transmission oil pan (Filter built into pan) my transmission took about 5L of ATF fluid
I also have a question for anyone with experience regarding this topic.. The transmission shop i went to today used "Mannheim" Dextron VI (6) fluid today instead of the usual ZF. while it seems to operate just fine, does anyone know if this oil is compatible for the 8 speed ZF or not? I obviously trust the shop especially after noting that the drivetrain operates much better then before, but second opinions would be much appreciated. Thanks all! |
12-06-2016, 12:19 PM | #2 |
164
Rep 598
Just a side note, but many E90 series cars have a GM transmission. One notable difference is that the filter is separate from the pan.
I am curious why your shop used Dextron VI in your ZF transmission. It's what is specified for the GM transmissions. That fluid isn't what is specified by ZF. |
12-06-2016, 12:22 PM | #3 | |
536
Rep 2,825
12-06-2016, 12:33 PM | #4 | |
536
Rep 2,825
12-06-2016, 03:03 PM | #5 |
37
Rep 134
I personally, always stick to the OEM stuff. And never believe 'lifetime' fluids. It just means for as long as they care about your car, which is ends around 50k miles.
STR8-6IX536.00 desertman1232213.50 |
12-06-2016, 03:06 PM | #6 |
7478
Rep 10,120
Had my pan\filter and fluid changed about 4k miles ago.. At 64.5k now.
Also did the differentials power steering and transfer case fluid at 60k miles. Coolant was recently done so not worried about that. But yes I HIGHLY suggest you keep up with your fluid changes. |
richsnuc17.50 |
12-06-2016, 03:09 PM | #7 |
164
Rep 598
My 2008 E90 N51 has a GM unit. I'm not sure which models got GM. It's recommended that you look up by your VIN to see which one you have, so I'm guessing it's not always a year/model breakdown. On the upside, GM does make really good transmissions, and it's extremely rare to see one fail in our cars, even without fluid changes. My observations online is that the ZF units do better with regular fluid changes, and you can get away with fewer fluid changes in GM ones. That's just an uneducated hunch. I changed the fluid and filter in mine at around 65k just because I had a good opportunity to do so.
As for your fluid, I really can't say. I think I've heard of people actually getting ahold of ZF engineers, so if that's possible it's a good question for them. Fluids are tricky. I always use exactly the fluid the manufacturer recommends. There are many scenarios that you can have otherwise: a fluid may be better, it may not last as long, it may be just the same, or it may be damaging. In your case, the shop probably just regards that fluid as an acceptable substitute based on their experience. It may or may not be. But they should have first asked you whether you were ok with a non-approved fluid. |
12-06-2016, 03:13 PM | #8 |
536
Rep 2,825
agreed, lifetime is a load of bullshit. they want the two most costly things in your car (engine + trans) to break right after your warranty is up by "recommending" 15k oil intervals and "lifetime" zf fluid intervals. my transmission fluid was pretty much almost black when i changed it at 111,000KM.
12-06-2016, 03:15 PM | #9 | |
536
Rep 2,825
12-06-2016, 03:17 PM | #10 | |
536
Rep 2,825
thanks all for your input!! |
12-06-2016, 03:18 PM | #11 | |
7478
Rep 10,120
EDIT: I did the rear diff on my old E90 328i (rear wheel drive) when it hit 80k and man it looked grimy. |
12-06-2016, 04:23 PM | #12 |
11
Rep 344
OP, thanks for the heads up. My car just turned over 60k three weeks ago, I guess it's time to take her in for transmission fluid change. I, too, have noticed some noticeable harsh shifts from time to time, but it usually happens when I back out of the driveway, and shift it to D, when the car is cold. So I just chocked that up to the car not being warm enough yet.
Hopefully I'll feel a noticeable improvement after the fluid change. |
12-06-2016, 04:34 PM | #13 |
228
Rep 1,045
Generally E9n 328i have GM tranny, while 335i have ZF tranny.
Per BMW (at least, per the 2011 3 Series Service & Maintenance book) BMW has a 100k miles explicit change interval for a/t, altnough the official ZF position is every 60k miles Last edited by Wilt; 12-06-2016 at 04:43 PM.. |
BKBMW335I156.50 |
12-06-2016, 05:35 PM | #15 | |
536
Rep 2,825
12-06-2016, 06:22 PM | #17 | |
964
Rep 3,854
Drives: 330i, 135i
Thanks for sharing. Not familiar with "Mannheim fluid" I changed mine about 2 yrs ago at around 105k miles as I was starting to have some random jerky shifting. I did not use ZF fluid, I used the Castrol fluid. So far so good but I feel I should do another one since I only did the flush and changed filter pan. So far so good... |
12-06-2016, 06:26 PM | #18 | |
536
Rep 2,825
12-06-2016, 06:52 PM | #19 |
55
Rep 266
My car is at 145K miles and has been experiencing very hard shifting. Sometimes it will jolt when changing gears and other times it seems like it will hesitate or wait too long to shift. In other words, definitely not as smooth as before.
I keep hearing so much back and forth. Some say don't do it while others say hurry up and do your transmission a favor by changing the fluid. Yes, I keep hearing the horror stories about transmissions failing after having a fluid change for the first time after passing the 100K mark, but the thing is that I know the transmission is not acting as it should. I definitely want to change it but I'm afraid of ruining the transmission.
2007 335i E92 FBO | MHD Stage 2+ 93 octane | xHP Stage 3 | Fuel-It! Stage 2 LPFP | VRSF 7" FMIC | VRSF Catless Downpipes | ER Chargepipe | HKS SSQV4 BOV | Ultimate Racing CAI
12-06-2016, 06:55 PM | #20 |
287
Rep 595
ZF Tranny Cars = 325i/330i/335i
GM Tranny Cars = 328i This applies to all US E9x vehicles, regardless of model year. |
12-06-2016, 07:02 PM | #21 | |
536
Rep 2,825
hesitation to shift up is a definite sign you need a fluid change. get it done asap. |
12-06-2016, 07:03 PM | #22 | |
536
Rep 2,825
also, how about e60? did this apply to that chassis as well? |
