328i power loss *with video*
12-05-2016, 03:56 AM | #1 |
40
Rep 204
Hi, I'm having an issue with my 2008 328i currently has 97xxxx miles, every time I push on tge gas the revs move up slower than normal halfway pedal sometimes it wont downshift until almost to the bottom, this is what I've done so far:
Checked Eccentric sensor for oil Cleaned MAF sensor with MAF cleaner Replaced air filter Did reset adaptions And just replaced spark plugs not coils After I replaced spark plugs I rev it up to 1000 rpm and when I let go of the gas it wants to stall around 600 but catches itself... So now I still have that second hesitation during downshift and a slight idle issue, what else could I look out for? Sorry for the long thread btw.... Last edited by Snoball M3; 12-09-2016 at 07:45 PM.. Reason: Added Video * UPDATE* |
12-05-2016, 04:48 PM | #3 |
Apprentice
373
Rep 801
Are you still on the original coils? When I had my 328i, what your experiencing was the same thing symptom that I had when I needed to switch out my coils.
Once I changed those, that little stutter went away. |
12-05-2016, 05:03 PM | #5 | |
40
Rep 204
I know these N52's has a lag normally but mine takes way longer to respond... |
12-05-2016, 05:06 PM | #6 |
40
Rep 204
12-05-2016, 05:09 PM | #7 | |
Apprentice
373
Rep 801
I just had to replace the coils on my 335i. This time around, when I needed to merge onto a freeway onramp fairly fast (thanks LA speeders) I had almost no acceleration. Once I got to about 65 mph the car was running fine. I hooked up to Carly and read a misfire. I replaced all of the coils, problem solved. My 328i started with what you have shown in the video. Then it turned into a nasty rough idle. Different symptoms. If I were you, I would: 1. Probably seriously consider purchasing Carly + OBD adapter. It's one of the best investments you could make for your car. 2. Replace the coils. |
12-05-2016, 05:17 PM | #8 | |
40
Rep 204
Ok I'll get on that, cuz I wasn't having any issues with the idle before I changed the spark plugs as soon as I changed them it started, but I'll update after I install the coils As far as codes being thrown, there isn't, is it possible for the coil to go out with no code? |
12-05-2016, 05:27 PM | #9 | |
Apprentice
373
Rep 801
Do you have a BMW scanner? Or are you using a basic scanner from an autoparts store? |
12-05-2016, 05:32 PM | #10 |
40
Rep 204
Ok good to know. Yeah just a regular one, would the Carly or BMW spec pick up the failure?
12-05-2016, 06:18 PM | #11 | |
2188
Rep 5,002
With these cars it's certainly in your best interest to have Carly, Bavarian Technic cable, etc.. |
12-05-2016, 06:40 PM | #13 | |
40
Rep 204
Just ordered new coils, I'll be sure to update the outcome |
12-05-2016, 06:45 PM | #14 |
40
Rep 204
I tried it in DS mode but thats it, but it runs smooth and more responsive the pedal has that heavy feeling, but as soon as I put it in D the hesitation is there again when downshifting and that heavy pedal feeling is gone. But I'll see if the coil replacement will take care of that.
12-05-2016, 06:50 PM | #15 |
181
Rep 657
Hope that takes care of it!
Just FYI: I have an 08 328i AT and my idle sits at 550/600 unless I have heat/AC on then its 650/700 according to the dash. When I hook up INPA and read values INPA gives me readings 100 over the dash. I have never been able to figure out what is right but the car runs great. I recently replace coils/plugs and didn't notice a difference but hey as long as the car is consistent I'm alright with it. You look like you have a more serious problem than me though based on your video and down shifts. Edit: I did have a slight idle hunt going on before the coil/plugs got replaced and that stopped afterwards. |
12-09-2016, 07:44 PM | #16 |
40
Rep 204
So update on my issue,I received coil pack from amazon, turns out 3 brand coils were bad
Threw me 7 codes and for some reason threw the camshaft positioning sensor too but the code went away. Anyway I still have the same issue after replacing the coils. My 328 is also SULEV I understand there's any emissions warranty on these for 15 years or 150,000 would they charge me for diagnostic? Heres a code it threw but couldn't find any info on C0300 |
12-12-2016, 01:53 AM | #17 |
Rep 11
Drives: 2008 328i E92 6MT TiAg/black
I had spikes in the RPM to 1000 at idle and it was my eccentric shaft sensor. No Engine light. No oil on sensor. Exhaust sounded like a low tone and softer. Harder to engage the clutch at 1st gear. Low power also. Did you get plausible eccentric shaft sensor code?
12-12-2016, 02:20 AM | #18 | |
40
Rep 204
