12-04-2016, 01:59 PM | #1 |
2281
Rep 4,933
Disable or code gearbox from learning...
Is there a way to do above?! After a reset things were better but hesitation in comfort is creeping back and annoying. Due to my commute it is all slowish acceleration but eco cr8p doesnt give enough (or any) acceleration from round abouts so I dont use it.
Comfort would be fine if it stopped thinking thats how I want it to respond all the time! |
12-04-2016, 02:58 PM | #2 | |
6659
Rep 15,858
If you are referring to driver influenced adaptation, it is real time adaptation. Drive harder it should be with you in a couple of moves. Drive in slow traffic flows and it gets lazy, (by design), a couple of dabs on the throttle and a few more revs and it is alive again. My gearbox is the same today as it was when I got the car, over 4-years ago. Always responds to my driving style within seconds. You can break driver influenced adaptation anytime you like, simply by flicking the shifter to M/S and back again. Any hesitation in the gearbox can't be driver influenced adaptation, it has to be something else, driver adaptation starts afresh each time we start. The throttle reset, seems a hit and miss affair, has been since we first had drive by wire. Never felt the need to try it in my 535i. Did try it in my 330d when others were saying it transformed the 6-speed. Never did anything to my gearbox, then I never had issue with it anyway. I really don't understand why the pickup become hesitant with some cars, others never have an issue. |
12-05-2016, 02:30 AM | #3 |
405
Rep 1,034
Why not just put it in sport mode, that sharpens things up and I much prefer it. I just wish I could code it to always start in sports mode. BMW have allowed for the possibility that you may always want to start in eco pro mode (god knows why) but not for sports mode
12-07-2016, 03:21 AM | #7 |
30
Rep 47
I would prefer it, if you could separate the systems like Audi give you control over.
Sometimes I want the throttle response of sport, but I don't want the additional revs that Sport gives you with the gearbox. There should be individual settings for throttle, steering, gearbox and suspension (if you have that option) and you could tailor it to how you like it. Sometimes I want a crisp throttle response, but don't want the car sitting over 2K revs in town. If I want to do that I have to flick over to the left and change manually. |
12-07-2016, 03:58 AM | #8 | |
759
Rep 1,863
TheFifthElement29.50 |
12-07-2016, 05:42 AM | #9 |
30
Rep 47
Nobby Clark I agree. Although dynamic mode in the S3 basically meant dropping it into the lowest gear at all times. So in town, you're never out of 1st and 2nd. It's basically a track setting where you either braking or accelerating at all times. It was even frustrating on a B-road hoon as you're not always 'on it' and you'd find yourself going along a straight road in 3rd engine screaming away for too long.
I'm the same really, comfort mode around town and motorway, then sports mode + manual shifting when I want some fun or want to overtake. |
