Help. Resetting Yellow Service Engine Light
12-03-2016, 06:14 PM | #1 |
Rep 10
I currently have a yellow service engine light on, which is preventing me to pass state inspection. I ran the OBII code reader and is getting the following codes; P0050, P0306, P0304, P3027, P0305, P0303. I'm guessing it is related to the oxygen sensor that needs to be replaced. Any ideas on how to reset the service engine light or would I have to replace the O2 sensor first to get the light to go away?
12-03-2016, 08:22 PM | #3 | |
1903
Rep 6,968
always replace o2 sensors in pairs. |
Bluewater328iT86.50 |
12-03-2016, 08:54 PM | #4 |
1208
Rep 2,835
First before replacing anything, clear the fault to see if it comes back.
Emission faults can from things like bad gas, loose fuel cap, etc. Had some enterprising mechanics that would during emission tests in Northern Virginia would either read a fault or create one and then fail the vehicle.... then charge the person anywhere from $1500 to $4000 for the repair. Which tended to be just clearing the fault. |
Efthreeoh17313.50 |
12-04-2016, 09:42 AM | #5 |
3537
Rep 3,049
You can clear the codes, do homework on the specific codes because they will need to be resolved before it will pass inspection. They will still be there even if you clear them and the inspection will show them as pending. Either way, the issues will have to be addressed.
12-04-2016, 12:09 PM | #6 |
28
Rep 110
Not sure how the heater circuit is on these cars for the O2 - if it is fused or not. Make sure you check your circuit before just throwing an oxygen sensor at it. Could be as simple as a fuse for the O2 heater circuit.
12-05-2016, 06:38 AM | #7 | |
1903
Rep 6,968
The two rear 02's (post-cat) just check to make sure the two front O2's are doing their job (Pre-cat). The most common culprit is the pre-cat's. I have 133k on my 335i and have never changed the post cat 02's. |
12-13-2016, 06:35 PM | #8 |
Rep 10
I cleared all codes. Only code P0050 remains, which is dealing with bank 2 sensor 1 O2 sensor. I plan to clean it over the weekend to see if the codes clear and service engine light disappears. If doesn't clear, I am going to replace the entire O2 sensor.
12-13-2016, 06:47 PM | #10 |
147
Rep 500
Agree. The heater circuit is part of the sensor and wiring itself. Just replace the precat sensor. Might as well do both while you're at it. The other one is likely to fail soon too.
12-14-2016, 12:00 PM | #11 | |
17314
Rep 18,737
OP, I did a DIY to replace the exact same sensor that failed on your car. You need to pull the cabin airfilter housing and the engine cover to get to the end of the harness where the connector is. http://www.e90post.com/forums/showthread.php?t=459104
