12-03-2016, 01:25 PM | #1 |
70
Rep 311
autobox
hey guys
just a quick question. I've got a 325d auto and some times when I put my foot on the accelerate it takes a second or so to actually go. is there any way to make it more responsive? cheers |
12-03-2016, 01:27 PM | #2 |
451
Rep 1,201
Do you have the standard auto of the Sports Auto?
Sports mode usually sorts that out. There is a slight hesitation in comfort (or below)
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
12-03-2016, 01:56 PM | #3 |
1983
Rep 3,216
Yay, someone else with a 325d !
All these 335d / 340i are so common, I think the real elites are those with the really rare engine setup. As to your question, sorry, can't help. Mine's a manual box |
12-03-2016, 01:57 PM | #4 | |
70
Rep 311
I didn't know if something could be coded to make it more responsive. I always forget to put it in sports mode lol |
12-03-2016, 02:04 PM | #5 | ||
409
Rep 1,162
12-03-2016, 02:15 PM | #7 |
451
Rep 1,201
As has been said, if you have the paddles it's a sports auto.
2TB can be coded into a standard auto and some have said this improves response. I have sports auto and I love the stick to the left and Sport or Sport+ mode. Smooth as silk through the gears.
12-03-2016, 02:57 PM | #8 |
2281
Rep 4,933
If you are in comfort mode and it happens then do a gearbox reset, a quick search on here will give the method and really helps. The gearbox learns the driving style which if you are in a lot of traffic means it learns to dull responsiveness, failing that live in sport mode!
stu14t450.50 |
12-03-2016, 03:05 PM | #9 |
2221
Rep 5,897
Drives: 2014 335i Black F30 M Sport
Bit off topic, but what kinda spec is the 325d in terms of nm and bhp?
12-03-2016, 03:35 PM | #10 |
13
Rep 55
I have a f31 325d , I noticed the same time , I normally put the the car into sport mode and move the gear stick to sport mode and it cure its
12-03-2016, 03:52 PM | #11 | |
3531
Rep 11,292
https://en.m.wikipedia.org/wiki/BMW_3_Series_(F30/F31) 160 kW (215 hp)@4400 450 N·m (332 lb·ft)@1500-2500 Also was the only other f3x that had two turbos, like the 335d iirc
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
CazuaLLUK2221.00 |
12-03-2016, 04:09 PM | #12 |
137
Rep 680
I think the old 325d in the e90 range had the same 3.0L as the 330d and 335d almost certain the 325d in the F30 uses the 2.0L tractor engine same as the 320d
I would try the accelerator peddle reset, my 330d has the same issue i am guessing BMW gear the comfort and Eco modes for highest mpg so may place the engine into some state that takes a few seconds to get out of or i may be talking out my arse. After i stopped doing motorway miles my 30d started to feel more pronounced hesitation when pressing the go peddle so it could be the car learning a new driving style or doing a quick gear change from 8th to 7th (no idea) - my 30d loves to sit at the lowest possible rpm in comfort and thus has a little turbo lag before pressing on unless you stand on the go peddle in which case it will simple change gear and off we go. It is slightly irritating but nothing that bothers me.
Current: None
Previous: E92 320d, E92 LCI 330d F30 330d, F32 440i |
12-03-2016, 04:11 PM | #13 | ||
451
Rep 1,201
And after a bit of searching, I found this on how to do it: Quote:
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 12-04-2016 at 10:11 AM.. Reason: Changed from 5 Sec to 2 min as per Rukka in Post #15 |
Skello45.50 |
12-04-2016, 05:52 AM | #14 | |||
70
Rep 311
12-04-2016, 05:59 AM | #15 |
2647
Rep 3,664
You need to hold the accelerator down for two minutes - not 5 seconds. Rest of the procedure is right though
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
