Chasing an oil drip...
12-02-2016, 09:16 PM | #1 |
Carbon Fiber Everything
12
Rep 74
Drives: 2009 328i xDrive
What do you guys think? Oil pan gasket?
12-02-2016, 10:01 PM | #2 |
90
Rep 386
Drives: 08 535xi 11 328xi
did you check the oil filter housing gasket, it will run down the front of the engine and run along the oil pan.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
12-03-2016, 07:25 AM | #3 | |
12
Rep 74
I will be changing the oil filter housing gasket anyway when I retrofit an oil heat exchange from an E60.
12-03-2016, 07:50 AM | #4 |
17315
Rep 18,737
Looks like the pan gasket to me. If the OFHG is leaking to get that much oil onto the pan, then the front of your engine will be a complete mess. You have a bunch of oil at the bottom of the bell housing, which indicates the the back of the pan is leaking.
12-03-2016, 06:51 PM | #5 | |
12
Rep 74
Well this sucks. I read the DIY for this on this forum, it does not sound like a fun time. Even though that option doesn't require you to drop the subframe it still scares me. Even the method that removes the oil pan completely that require the subframe removed looks terrifying. Anybody ever paid to have this done?
12-05-2016, 01:27 PM | #6 |
196
Rep 458
Check to see if the pan bolts are properly torqued first. It might help. Let us know what happens...
12-05-2016, 03:07 PM | #7 |
255
Rep 2,547
Cost $1000 (covered by warranty for my CPO) at the dealer.
12-05-2016, 03:11 PM | #8 |
1007
Rep 2,108
You need to look at AWD oil pan gasket replacement prices, because that is more work due to front differential being bolted to the oil pan and the passenger wheel axle going through the oil pan through a tunnel.
12-05-2016, 09:43 PM | #9 | |
113
Rep 450
You should always try this first, it works a lot of the time, especially if it's a high mileage car. Just be careful not to over-tighten because the aluminum bolts will break easily. Not too much pressure. Use a small wrench and when the bolt shows resistance to turning, stop. |
12-09-2016, 03:49 PM | #10 | |
12
Rep 74
Might check this weekend, I hear my area is getting some snow dumped on us.
12-10-2016, 12:56 AM | #11 | |
310
Rep 1,016
12-10-2016, 02:24 PM | #12 | |
1007
Rep 2,108
You can try to tighten those bolts just a bit more. But in my experience it may at best stop the leak temporarily, and soon you still will have leaks again. |
