BMW X3 Forum
BMW X3 Forum
      12-02-2016, 12:36 PM   #1
bimmean3x5x
Drives: BMW X5 35i MSports
Carly for BMW WiFi OBD 2 and Carly Pro App
Hi guys!
New here. Anyone tried this Carly scanner OBD 2 and the Carly Pro App?
First use would be in replacing my OEM battery with an aftermarket (after 5 years) and registering the aftermarket battery using the Carly Pro app.
Also, what's the best aftermarket battery can you people suggest?
X3 is 2011 F25 xDrive 28i.
Thank you!
      12-02-2016, 10:46 PM   #2
Asianoak
Asianoak's Avatar
143
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
I've been using the Carly app since my e92 with much success. The app makes coding easy and being able to read and reset obd codes is terrific as well.
I'm not 100% sure that the battery registration option is available for the F25 yet. I haven't looked recently so I'm not positive but I know it wasn't an option the last time I used the app. So double check first if that's your primary reason for getting it.
Instagram: @dasianoak
      08-07-2017, 08:26 PM   #3
Edward_s
Drives: BMW Series 1
Các ứng dụng làm cho mã hóa dễ dàng và có thể đọc và đặt lại mã số obd là tuyệt vời như là tốt.
      08-07-2017, 09:10 PM   #4
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
I have Carly and a coding cable and app. Carly pales in comparison. It's nice for quick, easy, simple changes, but the options are very limited in comparison to full coding capabilities.
That said, I coded 90% of what my wife wanted done in her X1 with Carly. Carly was only capable of maybe 50% of the coding I did to my X3.
As for batteries, I've always liked the Odyssey batteries. If I had to replace mine today I'd probably get a Odyssey PC1350.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      08-08-2017, 07:39 AM   #5
Lurcher
Lurcher's Avatar
75
Drives: 2012 z4
Curious - what could you not code with Carly? I need to know what I'm missing :-)
      10-24-2017, 06:05 PM   #6
Iowa X3
13
Drives: 2013 X3 28i
I'm curious also.
I started doing some coding with Carly the other night. Kind of annoyed I have to pay extra to code out the disclaimer. Also, I've disabled all of the available light bulb voltage checks (I have LED's in most) but I'm still getting warnings about the parking lights being out. Was really hoping to stop the warnings completely, not sure what the issue is there and haven't been able to find anything on it through Google searches.
      10-25-2017, 10:47 AM   #7
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
bimmercode app is better with Vgate wifi adapter.
i coded bunch of things without errors.
      10-27-2017, 11:05 AM   #8
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Did you code your Camera to work at any speed?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      10-27-2017, 11:08 AM   #9
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
i dont think i did that.
i took off disclaimer message, added //M to welcome navi screen, 100% angel eye , turned on rear taillight for drl, open/close trunk via remote and for windows and sunroof, added turning signal on headup display ..probably few other things i cant remember
FSociety3812.50
      10-30-2017, 01:04 PM   #10
lcoon
Drives: 2014 X3 x28i
+1 on Bimmercode & Vgate
Other than taking a couple tries to get Bimmercode to connect to the Vgate, coding worked like a charm.
BTW, was in contact with the developer, who told me Expert Mode will be avail on the Android version in about two weeks.
nyalpine907433.00
      10-31-2017, 03:26 PM   #11
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
bimmercode app is better with Vgate wifi adapter. i coded bunch of things without errors.
Wow, bummer, hadn't heard of this app, and I bought Carly a few weeks ago (yet to use it). So you're saying apples to apples comparison, their app codes a lot more things than Carly can? I know full blown coding cable with software does a lot more, but I thought Carly was currently the king of the coding apps?
Am I understanding correctly that the app itself is free, so your cost is just the Vgate Adapter, which is like $20?
App: https://itunes.apple.com/us/app/bimm...130787459?mt=8
nyalpine907433.00
      11-01-2017, 06:47 AM   #12
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
to download the app is free, to unlock coding its 34.99.
its very simple to use.
      11-01-2017, 11:30 AM   #13
Lotus99
Lotus99's Avatar
628
to download the app is free, to unlock coding its 34.99. its very simple to use.
Thanks. Can you answer this question of mine: So you're saying apples to apples comparison, their app codes a lot more things than Carly can?
What more can it do?
      11-02-2017, 06:17 AM   #14
nyalpine90
nyalpine90's Avatar
7433
2016 BMW X4  [9.33]
yes you can code more and yes cable and software does a lot more.
but with the app is simple.
      01-16-2018, 06:52 PM   #15
najnad
General of the Space Forces
najnad's Avatar
171
Drives: 11 X3 35i M-sport
Just got Bimmercode and coded most of what I want, really like that I was able to put the media info and phone info into the HUD! Havent tapped into the expert mode yet to see what else I can do that I cant do in the standard mode.
Is there a list anywhere comparing standard to expert mode for Bimmercode?
      01-17-2018, 08:40 AM   #16
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
I have both Bimmercode and Carly. Carly has more coding features than Bimmercode at this time. Purchased Carly for the battery registration feature to register my new battery. Bimmercode has a better interface and quicker than Carly. I don't mind Carly being a little slower but again more features than Bimmercode. Great thing about Bimmercode is the Expertmode feature. I hope Carly can add this feature in future updates. Carly tends to provide updates every month with new features. Bimmercode provides bug fixes each month so far with no new features at this time. Both apps were more convenient than setting up my laptop/esys.
As far as replacement battery... I replaced my oem 90ah battery with Advanced Auto 110ah AGM battery for $156 with discount/coupons. It was bigger in length than the oem but easily installed by moving the battery tie down bracket to accommodate the length. I was able to registered the new battery with Carly with no problems. Hope this helps.
      01-18-2018, 10:45 AM   #17
Riick
136
Drives: BMW
I use Carly on my X3. I used it on my E90 as well but the ebay adapter didn't work and had to spend the $$$ for the official one. No issues. Got rid of things like seat belt warnings and seatbelt light on dash, warning screens on I drive, play DVDs when moving, fold mirrors with key, close hatch with key, cameras on at any speed, engine start/stop defaults to "off" so it's never on unless you goto ECO mode, windows continue to work with doors open and engine off, and my all time favorite for every BMW: digital speed display on dash.
I'm sure I'm missing things.
      01-19-2018, 09:22 AM   #18
najnad
najnad's Avatar
171
Digital speed display on dash becomes redundant when you have a HUD...just sayin'
      01-23-2018, 06:45 AM   #19
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
120
Drives: X3 (F25) 2.0D, i3 BEV
Got the Carly BT Adaptor2 - have used it on my X3, i3 & daughters Mini.
Really easy to use, a bit slow but thats not an issue. Done the few niggles I wanted sorting and lest then £100 total so well pleased....
Happy to help anyone local to Plymouth UK too.
Have coded mirror to auto fold on locking and added a confirmation beeb. (on X3 & i3) Also made the tailgate shut from driver door switch.
Done a few other minor ones too.
BMW i3 (BEV) 2014. . Capparis White. . Park Assist, Comfort Access, Enhanced USB
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
Last edited by plymjack; 02-01-2018 at 10:59 AM.. Reason: added list of works done
      03-15-2018, 02:23 PM   #20
ReggieDoodle
Drives: 2012 X3 M30
Hi. Just bought a 2012 X3. Previously had an Audi with a large digital speed display and I miss it. Understand I can get something similar albeit small digits with the BimmerCode app.
What hardware do I need (cable / adaptor)? I have iPad, android phone and windows laptop so plenty options. Also got a fleabay OBD2 WiFi jobby somewhere if that can be used ?
      03-18-2018, 09:22 PM   #21
Lurcher
Lurcher's Avatar
75
Drives: 2012 z4
Unless you forget and grab your polarized sunglasses....
      03-18-2018, 10:23 PM   #22
antixian
Drives: car
i just tilt my head slightly and hud shows back up. it is slightly annoying but not too bad.
xbimmers
