12-01-2016, 11:50 PM | #1 |
648
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
6MT owners...who really uses 5th gear?
I love rowing through gears...manually, with a clutch. In fact, I've NEVER owner a car with an automatic transmission.
That being said, today's modern autos are both quicker AND more fuel efficient than their manual counterparts...due in no small part to their 8 cogs. I'm not overly concerned with acceleration comparisons, but I DO regret that my engine is spinning at an additional 500 RPM in 6th at highway speed compared to 8th in the auto. This got me thinking...5th is the forgotten gear (I NEVER cruise in 5th, even in town). Wouldn't it be grand if BMW moved the current 6th gear ratio to slot 5, and gave us a true overdrive 6th gear with a ratio closer to 8th in the auto? I realize it wouldn't be suitable for any type of hilly 2 lane highway (would force you to change gears too often), but for long, relatively flat freeway runs, it would be welcomed.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
12-02-2016, 04:29 AM | #4 |
Driver
465
Rep 1,002
Like you I hate auto boxes and love the flexibility of a manual. I use 5th all the time, only really go into 6th once I'm up to 80 plus on the fast lane (oops I mean outside lane)
On A roads it's usually 5th! But back to your point, I agree they could alter the ratios a little maybe for the top two gears! |
12-02-2016, 04:34 AM | #5 |
123
Rep 441
I use 5th when I'm cruising in traffic between 60 and 80km/h. I agree 6th could be just a bit taller to drop my engine speed below 2krpm at 100km/h.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
12-02-2016, 05:44 AM | #6 |
4062
Rep 4,984
Didn't realize that, thanks!
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
12-02-2016, 06:54 AM | #7 |
579
Rep 1,148
5th is a great gear, I know you shouldn't have favourites but this would be mine if you were allowed.
12-02-2016, 07:21 AM | #8 | |
731
Rep 1,472
Ha ha, no way, can't agree, it's gotta be 3rd, if you're picking favorites. |
12-02-2016, 09:19 AM | #10 | |
772
Rep 1,502
If there were opposites for this sort of thing it must be the corvette. Doesn't that go like 80 in 2nd, then you can just dump it straight into the super-overdrive top gear? But then it turns off 4 cylinders so I guess maybe it does end up like a 328i in top gear on the highway |
12-02-2016, 11:24 AM | #11 | |
1511
Rep 5,091
Interestingly on MY17, bmwusa spec shows that 320i also has direct at 5th just like 340i, while 330i still has direct@4th. That's surprising, maybe bmwusa has a typo? Last edited by bavarianride; 12-02-2016 at 11:31 AM.. |
12-02-2016, 02:20 PM | #12 |
155
Rep 2,266
I use 5th on surface streets that are not very congested. Also on the Freeway at 60-80 when you might need power on demand.
I too have never owned an AT. But this is one of the best MTs I've driven.
F30 Sapphire Black M-Sport 335i 6MT
12-02-2016, 03:43 PM | #13 |
Driver
465
Rep 1,002
A few of you have described 4th or 5th gear as the 'direct'... never heard this before, what does it mean (top before overdrive maybe?)
Also, anyone tell me roughly what speed you'd be doing in a 340i in 6th gear at 2k revs? |
12-02-2016, 04:36 PM | #14 |
714
Rep 1,329
They mean it is 1:1 ratio - same revs into trans as out of it. Most manual trans have 1 gear - usually the top gear that has a 1:1 ratio. Recently overdrive has been added to manual trans - some as mentioned have 2 overdrive gears, meaning output shaft spins faster than input.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
nozydog465.00 |
12-02-2016, 07:19 PM | #15 | |
1511
Rep 5,091
Then go look up the 6th gear ratio, e.g. 1:0.85, plus the rear diff ratio, e.g. 3.23. Then do this math: ((2000rpm/0.85)/3.23)/801 = 0.909 mile/min, or 54.6mph. |
12-02-2016, 09:13 PM | #16 |
16
Rep 311
Depends on traffic. but around here, I find myself in 5th fairly often. Also when on the interstate and i need to get around someone quickly, I'll grab it to get that little extra oomph.
So typical of the way BMW does this, 5th is the direct and 6th is the overdrive, 1.00:1/.85 :1 respectively. That said, with the emphasis on torque these motors have, it feels like they could have gone with a taller overdrive ratio, especially for the 435/440 models. That said, BMW has a long history of getting the gearing spot on. Loved running my 535 on the 'bahn and it would max out right at the horsepower peak in 6th |
AudiA4647.50 |
12-02-2016, 10:13 PM | #17 |
648
Rep 1,476
Interesting responses...clearly people drive their cars differently. I just never find myself using 5th. If I'm going more than 40, even in town on city streets, I'm in 6th. The car has plenty of torque, and when/if I must shift down, it's usually to 3rd or 4th.
I wouldn't debate that using 5th more frequently - or any other methodology - isn't just as valid as my practice. But from my perspective, I'd rather the 0.85 (current 6th ratio) occupy slot 5, and give us a higher, highway overdrive gear as 6th...especially on the 340/440's.
12-02-2016, 10:55 PM | #19 |
6086
Rep 3,627
My car is primarily used for highway commuting at 80-90mph. The 6 speed is doing 2900rpm at 80mph and the auto is 2200-2300.
I would have loved to buy a 6 speed if they threw in a long overdrive. Mainly for the reduced engine noise, but the added gas savings and having less wear on the engine would have been a plus too.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
AudiA4647.50 stopbeingabozo9.00 |
12-03-2016, 09:22 AM | #20 |
6659
Rep 15,858
Got to ask a simple question here?
Why would an MT user not use (or favour) a particular gear? Surely the idea of MT is to use the gearbox, and in this case (if efficiency is in the thinking) 5th gear would be a favoured gear to benefit from the gearbox design. The 1:1 in/out efficiency. As for a higher gear, again isn't that a compromise for a sport biased MT? Do you want a sport setup (close ratios) or an "oddity" overdrive ratio with a gap in overall ratios? |
12-03-2016, 09:50 AM | #21 |
421
Rep 842
I think the point here is that with all the HP and especially the super wide torque band the need for a close ratio manual is not really there, especially in the top gears.
This is especially noted in the highway RPM as stated above. The 4th gear could be 1:1 with the first three gears spaced close and the top 2 gears more highway oriented. |
AudiA4647.50 |
12-03-2016, 10:27 AM | #22 | |
6659
Rep 15,858
Personally I wouldn't want the top two ratios spread out, certainly not the top ratio. If we must have longer gearing, I would prefer a change in diff ratio to obtain the lower revs at cruising speed. But it is not that simple. I've driven MT with odd top gear ratios, we've seen it a lot in the UK over the years, they are not 'driver' biased, you have a hole in the ratios, whatever the engine characteristics. The other technical issue is the 'ratio spread' from the gearbox. There is only so much spread possible. Plus 1st gear must pull off on a specified incline, that limits the diff ratio. Therefore the 1st gear ratio, gearbox ratio spread (6-speed MT) and diff ratio, combine to limit the cruising rpm. The ZF 8-speed AT answers all the criteria, efficient close ratios, wider ratio spread (7.8) within the 'box, allows for longer gearing. |
AudiA4647.50 bavarianride1510.50 |
