12-01-2016, 03:58 AM | #2 |
4271
Rep 6,945
I have bought a 6 month and a 1 year old approved used before. My experience is that the warranty is actually very good - pretty much the same as a new car, which is fortunate as the 'extensive approved used check' actually just involves a wash and vac. I found numerous faults on both cars within minutes, but the dealers were happy to resolve them. On one car I could even see the fault on the pictures they had taken to advertise it!
I don't know whether they are as relaxed about doing stuff if the used car is beyond 3 years old, and so outside its normal warranty period. |
12-01-2016, 04:11 AM | #3 |
606
Rep 1,455
I bought a 328i in June
Had steering rack replaced under AUC warranty a couple of months later No cost, free courtesy car, no hassle at all Very pleased AUC cars from dealers are definitely more expensive but you only have to have an expensive problem to fix and it's worth it. Peace of mind. |
12-01-2016, 04:44 AM | #4 |
27
Rep 80
I bought my E91 as an approved used car at just under 3 years old and have kept it in the Comprehensive Component Warranty after the AUC's 1 year warranty ran out.
The car is now 9 years old and the warranty has been worth it's weight in gold, easily paying out more than i've put in each year. Just last year it had all it's gearbox seals replaced along with a wheel bearing (which was borderline as should be deemed a wear and tear item - my dealer argued it had failed as a manufacturing defect - i think there was a lot of goodwill with this one!). It also had a sump which had corroded excessively, a replacement valvetronic unit as it was using oil and had it's rear wash wipe spindle renewed as it had seized off. That's just off the top of my head, over the years it's had a ton of warranty work, seized rear calipers, a new tailgate through corrosion, a clutch and dual mass flywheel, abs pump due to a relay failure, 2 front springs i could go on and on........ If you're in it for the long haul, it's a no brainer to me to go for the extended warranty. Car was bought at 20k miles, now done 131k, maintained by same dealer since i bought it. These cars haven't got anywhere near the build quality of the E30's and E36's of yesteryear and also have way too much to go wrong. Never had any issue with BMW refusing a claim either. Last edited by magic juan; 12-01-2016 at 04:50 AM.. |
12-01-2016, 05:27 AM | #5 | ||
6659
Rep 15,858
I've not run a BMW out of warranty (new, AUC and extended) since 2002, saved a lot of money having the continuous cover. Just this week I've had over £1,000's worth of warranty work on my car. This year's warranty covered in one go, for two "small" items, rear air spring and side view camera. The more options and tech' we have, the greater the risk of high cost fixes. Last year, a 'simple' door handle (comfort access) fault, resulted in a recovery to the garage, due to a battery drain which messed many systems. New door handle was required at some astronomical cost, (yes a door handle), plus the fitting and recovery, hire car for 3 days and return on a flat bed, covered my warranty cost. I've also had the "big" one, a new V8 engine at 65k miles, total bill was well over £12k with consequential costs, 2 recoveries, hire car for over 8 weeks, etc. All sorted under the extended warranty, without any cost to me. We can self fund (bank similar values), and/or find cheaper solutions outside the BMW network if we have failures. We may come out of it in pocket. In my experience I'd be way down and out of pocket, compared to having the full cover and a 'one stop' solution (with BMW) for faults and failures. Regarding wear and tear, quote from BMW Warranty T&Cs: Quote:
12-01-2016, 06:41 AM | #6 |
4271
Rep 6,945
My car will probably hit 43k miles by the end of the 3rd year. I intend to run it until 6 years / 80k miles. Anyone have an idea how much those 3 years of warranty would cost?
That should help me work out if the warranty is worthwhile. For those who suggest that they have had x amount of work carried out under warranty, I think you should be taking into account what BMW would actually charge after goodwill. For example a friend needed £4000 of suspension work on a 4.5 year old F11 - BMW charged him about £1200. Someone on Pistonheads needed a £12k engine for his 5 year old 535d - BMW charged £2k. I have run several BMWs outside the warranty period, and so far it has worked in my favour - I have spent far less (after goodwill) than the premiums. I am conscious that cars are getting more complex though, which tips the balance towards the warranty. There is also the unquantifiable benefit of not having to worry about it. |
12-01-2016, 07:07 AM | #7 | |
224
Rep 3,016
However, as other's have pointed out, I think it's absolutely essential to have BMW insured warranty when the original expires. Certainly, there are many cheaper third party insurers but I don't think the coverage is as comprehensive and AFAIK you have to get their approval before work can begin. With the BMW warranty you simply take it the nearest dealership and they take care of everything. |
12-01-2016, 07:10 AM | #8 | |
224
Rep 3,016
Go BMW warranty on-line and get a quote. |
12-01-2016, 07:52 AM | #9 | |
4271
Rep 6,945
Comp with zero xs £691 / 610 (with/without breakdown) Comp with 250 xs £410 / 329 That is cheaper than I imagined, and apparently the key price change point is at 60k miles. For two of the three years of extended warranty I would be below 60k miles at the start. At this level, it looks worthwhile to me too. It looks like the full 3 years of extended (zero xs) comprehensive cover (exc breakdown) will be around £2k in total |
12-01-2016, 08:01 AM | #10 |
27
Rep 80
That's the thing Pete, my car had done well over 120k on the original bearing at the time, both my dealer and BMW could have told me to sling my hook, however there was no issue at all.
Fraser Murdoch, who is the service manager at Parks is an absolute asset to the company. Great guy to deal with. |
12-01-2016, 09:05 AM | #11 | |
224
Rep 3,016
12-01-2016, 09:10 AM | #12 | |
224
Rep 3,016
To protect yourself from any nasty shocks down the line it might be a good idea clarify that you'll probably exceed that during the warranty period. |
12-01-2016, 09:32 AM | #13 |
4271
Rep 6,945
I don't think they will allow me to buy all 3 years at once, but I am assuming £610 + £610 + £800 (guesstimate for the last year, which starts at over 60k miles)
12-01-2016, 10:51 AM | #14 |
130
Rep 358
The lower mileage user has a more difficult decision,I think.
At,say,5k miles per year,then 15k at 3 years old and out of warranty. So if kept another 3 years, then only 30k at 6 years old. Now I would have thought that any faults in years 4 to 6 were in these circumstances: a) Unlikely b) Should be covered by a large dollop of goodwill if they did occur. Assuming the BMW service history is as it should be,of course. |
12-01-2016, 11:22 AM | #15 | |
4271
Rep 6,945
12-01-2016, 01:25 PM | #16 | |
224
Rep 3,016
12-01-2016, 04:23 PM | #19 |
4372
Rep 4,230
Don't know if they have changed, but when I was a service advisor UCW didn't cover rattles, trims or adjustments.
Also it didn't cover all investigation work for some of the harder to diagnose problems. We used to get customers to authorise an hour of diagnosis time and then try to claim what we could with BMW. Just a couple of points where UCW differs from manufacturers warranty. |
12-01-2016, 04:51 PM | #20 | |
6659
Rep 15,858
Relationships with dealers can also have an influence, but again no guaranties dealers can influence a negative decision from BMW. Service record is also important to goodwill gestures. The term 'goodwill' for part payment from BMW, still has rules in place. The warranty is really the only 'peace of mind' solution, unless we have a lighter view of risk. Or are prepared to battle with BMW, if we feel we have a legitimate case for 'cutting a deal' on premature repairs. My family have just gone through a difficult case with VW, no warranty but clearly a major and premature failure. VW don't want to know, even though the mileage is low for such a failure, the bill is typically around £6k. The dealer is prepared to do the work at cost, as the family spend a lot with them, for vehicles and servicing. An extended warranty would have had a better and much cheaper result. |
12-01-2016, 05:00 PM | #21 | |
1983
Rep 3,216
When you consider that they'd have the right to throw out a claim if it wasn't all recorded to spec, then I'd imagine the additional cost of getting the work done by a BMW dealer isn't worth the potential grief of getting it done by an indie and then finding out some little item was missed out, and your claim being rejected as a result. finally, do bear in mind that any 'goodwill' matters will be far more likely to be rejected if you've been getting servicing carried out outside the dealer network. Last edited by robbiep; 12-01-2016 at 06:07 PM.. |
12-01-2016, 06:02 PM | #22 |
1535
Rep 2,217
Had an AUC warranty on my E60, then a further warranty package once AUC had run its course. Had three claims which were dealt with without me even having to blink. Credit where it's due; 75 quid a month soon paid for itself in spades.
