Smoke from right side wheel well
11-29-2016, 02:41 PM | #1 |
Rep 1
Hello everyone, I am new to the forum and just purchased a 2011 335i N55 automatic / M Sport. My issue is that I took a few runs with a buddy with a ZL1 camero and after the first hard run after I stopped there was white smoke coming out of the passenger side front wheel well. I did not go hard on the brakes to slow down and it didn't smell like brake smoke. I looked all around the car for oil and did find any leaks or drops on the ground. The smoke was short lived and actually didn't have much of smell at all but it was windy that day. My car has 64k on the motor. Any idea where that smoke could have came from? Surely this car can handle a couple of 1/4 mile runs with no issues. As I am sure is the case with most of us on here, I didn't buy it to sit in my garage. This car "currently" does not have any tunes or upgraded parts that I can see. Needless to say I haven't got on it since then. Any ideas would be appreciated.
11-29-2016, 02:44 PM | #2 |
266
Rep 952
When is the last time you changed your brake fluid? White smoke billowing from the wheel well is often the brake fluid boiling in the caliper and escaping past the caliper piston seal.
The older the fluid, the more water is has absorbed, the lower the boiling temperature. BMW recommends new, DOT 4 fluid every 2 years. If you compare DOT4 fluids you still find some have a higher / lower boiling temp. A slightly sticking caliper will cause this to be worse, as will the rain sensor being triggered and 'drying' the brakes by dragging the pads slightly.
bone stock
11-29-2016, 04:00 PM | #3 |
1073
Rep 1,957
Drives: E90 M3 LCI Jerez Black
Sounds like a sticky caliper.
Was the alloy hot to touch? |
Tags |
n55 2011 335i bmw e92, smoke |
