3 inspection error codes
11-29-2016, 11:44 AM | #1 |
Rep 97
Hello all.... I think I assumed to much :-(
2 days left and I just failed my inspection with 3 codes. The guy asked if I had disconnected the battery and I told him I hadn't, because there were no codes showing but the status was "not ready" so I should drive 70 miles and come back to test again? I haven't done any work on the car recently so my best shot is defective sensors? Any help and info on a direction I should go is appreciated. 1124 differential pressure sensor 1197 bank 1 2402 evaporator leak detection pump I've attached the sheet from the inspector, thx again! |
11-29-2016, 12:00 PM | #2 |
232
Rep 649
Drives: F80
Check this out for resetting sensors: http://www.obdii.com/drivecycle.html
Follow that on a cold start day, and you should be good and sensors should be ready if nothing is malfunctioning. Shouldnt need to unplug battery. |
