11-28-2016, 10:29 AM | #1 |
Rep 1
engine overload (late 2009 e90 318
The engine of my slate 2009 e90 318i (petrol) has begun losing power on hills or at low speeds (where it didn’t in the past) — to begin with in 3rd gear, then 1st and second, and now in 4th. This is sometimes accompanied by a white flashing warning light which apparently means “Engine fault under high loads. High engine load will result in damage to the catalytic converter.” This light goes off when I switch off the ignition and doesn’t come on again when I restart.
The car is also increasingly reluctant to start unless I give it a good blast on the gas pedal. Does anyone have any idea about what the cause of this might be? (It reminds me slightly of the previous model 318i I had a couple of years before this one which needed all its injectors replacing over the course of about 18 months.) Any thoughts would be gratefully received. |
11-28-2016, 10:30 AM | #2 |
1397
Rep 8,083
Coil packs.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-28-2016, 12:02 PM | #4 |
3489
Rep 9,709
Oh I love these competitions.....Guess what's wrong with my car
My guess is a family of Ferrets have taken residence in the air box, blocking airflow. Am I close? Whats the prize? Last edited by NISFAN; 11-28-2016 at 01:33 PM.. |
stu14t450.50 Steven1077240.00 |
11-28-2016, 12:41 PM | #5 |
126
Rep 641
Could be many things. Way back in the day I had an E36 318is Sport Coupe and due to a faulty sensor the catalytic converter choked from over fuelling. Symptoms where a gradual loss of power to the point where I could barely drive at walking pace. When it eventually died it wouldn't start because of excessive back pressure in the exhaust system. End result was new sensor and catalytic converter.
Get it looked at by someone who knows what they are doing, could save you some money. |
