11-28-2016, 04:29 AM | #1 |
2647
Rep 3,664
440i - Exhaust Flap Mod - The Proper Way...
So I looked at getting the LH exhaust open all the time with the hope it might sound a bit beefier. On REALOEM it showed a part for use with the MPE which is called a "dummy flap actuator" - in effect, a blanking plug for when you disconnect the exhaust valve.
They were on back order - part number 18302411427 - and cost about £18. So back in October I ordered one and finally set about doing the job yesterday. Here are a few snaps of the part and the process to fit it. I noticed it had a little sticky out bit that looked like it would clip into a hole - more on that later. First job is to get the flap open. I started the car from cold then after about 5 mins flicked it into Sport+ and blipped the throttle (you can hear the flap open when you do this) Turn off the ignition and now the flap will stay open. Next job is to lie on your back and disconnect the servo cable. A small bit of plastic needs to be squeezed in and it come out easily. If you find yourself pulling at it, you haven't released it properly. Now with the cable disconnected, push the dummy flap actuator into the cable end and I was looking for somewhere to clip it up (using the little fitting on the dummy) No hole was evident in the immediate area; well, where the cable would reach to anyway so I looked upwards and spotted a piece of plastic covering that stood away from the boot floor. Trusty Dewalt to the rescue and a 6mm hole drilled in the plastic. And finally, clip it all up neatly out of the way First Impressions It certainly sounds better from behind and it's nice to see smoke (steam) coming out of both pipes equally. Driving it, it *does* sound a little bit deeper in tone but certainly not night and day. Testing it in the works multi-storey this morning, it did still go louder when in Sport mode so not sure what else is happening as it looks like it's not just the flap controlling the sound. Anyway, for those thinking about such mods, is it worth it? Well, I would say that for the look of getting both pipes open and equal steam coming out - yes. For additional sound, I would say not. I also noticed the car took longer to warm up this morning. I'll double check this later to confirm... Update - it takes no longer to warm up than normal. Rukka
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 Last edited by Rukka; 01-11-2018 at 05:09 AM.. |
11-28-2016, 04:47 AM | #4 |
1867
Rep 13,043
Drives: BMW M340I G20
So could you have pulled the original plug out slightly to disconnect the pins?
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
11-28-2016, 05:32 AM | #5 | |
2647
Rep 3,664
Having the cable disconnected won't throw an error light but I believe it stores a code for it. I wasn't sure if it did something else too - altering any engine parameters so fitting the dummy for £18 just made any niggles go away.
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
11-28-2016, 05:58 AM | #6 | |
1867
Rep 13,043
11-28-2016, 06:57 AM | #7 |
2021
Rep 1,926
Thanks for posting the DIY Rukka.
I'd say there are 2 stages of x40i exhaust mod. Stage 1: Do Rukka's mod. Get your hands dirty. Get steam out both pipes (always good ). Decide it's a bit louder but not enough. Stage 2: Think 'Feck this' and just get MPPSK One thing; my 340i with MPPSK definitely has vapour coming out of both pipes at idle when in Comfort mode. Not sure once underway however.
F31 340i | GS with CR & Ash Grain Trim | M Sport+ Pack | Prof Media Plus Pack | Interior Comfort Pack | Leather Dash | Folding Mirrors | Pano Roof | Elec Mem Seats with Lumbar | Adaptive Suspension | Comfort Access | Reverse Cam | Surround View | SLD | Rear Sunblinds | Folding Headrests | Model Designation Delete | Trim Designation Delete | MPPSK
Rukka2647.00 |
01-08-2018, 12:14 PM | #9 |
57
Rep 125
Anybody bought one of these online? Rybrook Warwick want £12.64 for p&p (presumably its coming from Germany) and was looking for another option. I know I could order from my local dealer but was hoping there was an ‘easier’ way of getting my hands on one.
01-08-2018, 12:51 PM | #10 |
1574
Rep 2,157
Drives: X3M Competition
Same price as eBay. I might order one.
CURRENT
X3M Competition- Toronto Red [url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Car[/url] |
01-08-2018, 02:56 PM | #11 |
614
Rep 1,799
I've bought from rjberry his 340i exhaust backbox with black tips to fit to my 335D.
I know I need to remove the electric actuator from the exhaust & then open the flap and weld/glue it so the flap remains open - exactly how do I do this (or more likely the chap installing the new exhaust ? I will contact Phil at Cotswold BMW tomorrow to buy the 340i rear diffuser so once this has been delivered it can be fitted - is this something the exhaust chap will replace or do I need to do it before I take the car - if so how do I remove/refit the diffuser ? My insurers have confirmed as this does not affect the performance of the car my policy remains the same without any premium increase.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
01-08-2018, 03:00 PM | #12 | |
2281
Rep 4,933
01-08-2018, 03:16 PM | #13 |
614
Rep 1,799
I understood you had to actuate it first to open it , which I can’t do as I have a 335D ?
Previous : 2019 F31 340i : 2017 F31 335D M-Sport Last edited by Steve_M_Sport; 01-08-2018 at 03:55 PM.. |
01-09-2018, 07:55 AM | #14 | |
2281
Rep 4,933
01-09-2018, 11:45 AM | #15 |
57
Rep 125
01-11-2018, 05:10 AM | #16 |
2647
Rep 3,664
After seeing this thread resurrected, and that Photo Bucket had blocked all the links, I have now added the original pictures to the first post for those that like visuals
Current: M4 G82
Southern Jay539.00 dazwhite23.00 AlwynMike336.50 RustyBitz1573.50 texasjohn41.50 Rhino at Work713.50 hudson012003168.50 |
01-11-2018, 06:34 AM | #17 |
337
Rep 1,660
01-12-2018, 07:05 AM | #18 | |
23
Rep 132
https://www.ebay.co.uk/itm/Original-...53.m1438.l2649 |
01-12-2018, 08:52 AM | #19 |
629
Rep 965
Drives: 2016 F36 435x MSport
The only poopy thing is people with F36's be careful. A lot of us have noticed that the F36 flapper doesn't exactly follow the same pattern as the other Fx's . I had to resort to using the steel wire mod since the F36 seems to only open when in motion above 3k rpm regardless of drive mode
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
01-12-2018, 09:24 AM | #20 | |
1388
Rep 2,127
Samuaw81.50 |
01-12-2018, 09:29 AM | #21 | ||
2281
Rep 4,933
01-12-2018, 09:48 AM | #22 |
1574
Rep 2,157
£45.48 for the part was just about to purchase until then. I will wait until I’m in Germany and get it delivered to the office.
CURRENT
