Misfires at idle
11-26-2016, 08:22 PM | #1 |
26
Rep 186
Misfires at idle
In reference to my wife's 07 X3 but thought you guys could help. Ran the codes getting misfires on 3 cylinders. This only occurs at idle, car (AT) jerks forward like someone slightly hits the car from behind. Once the car is going is smooth as silk. At idle with the AC on its worse. I've switched the coils around, still occurs but no new codes yet so I can't say its coils yet. Anyone know what would cause the misfires at idle? Its very noticeable. The plugs only have 10K on them.
thanks Steve
'11 E92, MSport 3 Pedal 3.1L Stroker Z Last edited by 3.1L Z; 11-27-2016 at 06:18 AM.. |
11-26-2016, 09:27 PM | #2 |
Apprentice
373
Rep 801
Have you ever changed the coils? If you haven't had them changed, then several of them might be going bad which means switching them around isn't going to do you much good. I would just change them out.
11-26-2016, 09:35 PM | #3 |
26
Rep 186
Its got 90k. Original coils and injectors. Would either one of these exhibit problems at idle but do fine at regular driving?
'11 E92, MSport 3 Pedal 3.1L Stroker Z |
11-26-2016, 10:14 PM | #4 | |
Apprentice
373
Rep 801
What it sounds like is your coils. When I had my 328i, the only thing that was bad was the idle. It drove fine. Once I changed the coil, the rough idle went away. It would be good if you change all of them at the same time. Not only are you future proofing, you should notice a performance bump. |
11-27-2016, 10:15 AM | #5 |
26
Rep 186
Holy shit. I really need to write stuff down.
Don't think I did the plugs last year. Could worn out coils do this? I usually put anti seize on plugs and nothing on these. Pretty tight as well so it makes me think I never did the plugs. On second thought these might be the Irdium plugs that have the tiny electrode...
'11 E92, MSport 3 Pedal 3.1L Stroker Z Last edited by 3.1L Z; 11-27-2016 at 10:22 AM.. |
11-27-2016, 10:47 AM | #7 |
Apprentice
373
Rep 801
I think its very safe to say we found the problem . Your car just needs a tune up that's all!
If I could recommend some parts, here is what I bought for mine: Coil Packs: https://www.amazon.com/Bosch-0221504...sch+coil+packs Spark Plugs: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I'm pretty confident this should fix your idling problem. Easy DIY too! |
11-27-2016, 03:34 PM | #8 |
Rep 38
yup sounds like new plugs and coils are due! Just did mine last weekend at 56k and cars running like new again. $229 for 6 bosch plugs and coils, simple job if you take your time and go step by step. Used this DIY and it was seamless
good luck! |
11-27-2016, 03:35 PM | #9 |
26
Rep 186
Well, new plugs and no more misfires. I must not have replaced the plugs. They could have had 90k on them.... Bought the car with about 40K on the OD. I'll get some new coils for the hell of it since they're cheap and probably needed soon anyway. Thanks.
steve
