help!-why did my 330i come with continental contipro SSR tires?
02-18-2006, 10:31 AM | #1 |
556
Rep 1,067
I just got my non-sport 330i yesterday. I thought
Bridgestone's were standard. Also, I looked up the tire on tire rack and this is not even an all season tire. It is a max performance summer tire. The tread will wear really quickly, and i dont want to have to replace them. Should I be concerned or did BMW change tire companys? |
02-18-2006, 10:42 AM | #2 |
146
Rep 898
Drives: F90 M5
Not really. You could even consider it as a bonus. I got the ContiSport Contact2 SSRs on my Euro 325i. I can't compare them with the other brands that come standard on the E90 but what I CAN tell you is that the treadwear index on the Conti's is 240 compared to all the other brand's 140. So in theory they should last much longer before they need replacing.
Anyone else got some input on how the Conti's stack up against the other brands on the E90? |
02-18-2006, 10:57 AM | #3 |
25
Rep 513
I would be concerned only if you plan to drive the car year-round without changing tires/wheels. But since you got an RWD car, I assume you were planning to change wheels/tires.
02-18-2006, 11:06 AM | #4 |
Rep 184
You can't really compare one tire brand's tread wear rating with another brand's. Each manufacturer uses different criteria to determine their tread wear rating, so you can compare different tires made by the same company, but not between companies.
02-18-2006, 11:29 AM | #5 |
146
Rep 898
Drives: F90 M5
Not that i'm disagreeing with you or anything, but doesn't that make the treadwear index largely useless?
02-18-2006, 12:47 PM | #6 | |
14
Rep 940
02-18-2006, 01:30 PM | #7 | |
Freude am Fahren
336
Rep 5,254
2.) The only Contipro tires I see on TireRack and Conti´s site are ContiproContact AS tires. Nothing even similar to ,,Contripro`` shows up under summer tires. Are you sure that´s what you got?
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
02-18-2006, 02:08 PM | #8 | |
556
Rep 1,067
Oh okay I think i got confused. I went to 06 330i and clicked base model OE tires: http://www.tirerack.com/tires/OETire...cleSearch=true I assumed those were mine cause mine have the SSR also. But then I went to check my car and mine say contipro and these say contisport. The SSR part and tirerack listing them under standard OE equipment confused me. Is this an error on tirerack's part? Because I dont see my conti pro under OE equipment. Someone might go to tire rack and mistakingly order these max performance summer tires thinking they were the base standard Continentals. Either way, I did some research and overall the continentals seem to be rated a lot higher than the bridgestone's so im happy. |
02-18-2006, 02:11 PM | #9 | |
Rep 227
02-18-2006, 02:14 PM | #10 | |
Freude am Fahren
336
Rep 5,254
Freude am Fahren.
02-18-2006, 02:34 PM | #11 | |
1312
Rep 10,185
BMW if you are reading, I need a job, Please. |
02-18-2006, 02:38 PM | #12 |
1312
Rep 10,185
The SSR on the Continental means its a runflat tire
SSR stands for "Self-Supporting Runflat" All E90 factories get tires from Bridgestone, Michelin, Continental and Pirelli. The 1 Series has started getting Goodyear runflats, do the E90 may aswell one day. USA cars used to mainly get Brisgestone All Season tires, but seems you now get the new Continetal aswell ( they never made that continental all season tire before in runflat for BMW)
02-18-2006, 03:11 PM | #13 |
25
Rep 513
As far as I know, the RFT all-season Bridgestone Turanza EL42's that came with non-SP RWD models and all AWD models basically sucked. The 6 reviews on TireRack were all from E90 owners and they all hated the tires.
Looks like these SSR ContiPro's are new to the E90; at least nobody's put up a review for them on TireRack. Maybe they'll be better than the Bridgestones. |
