11-23-2016, 11:46 AM | #1 |
452
Rep 986
removing old wheel weight sticky foam
I was cleaning my wheels last night before swapping over to my winter set, and i noticed when i got new tires they didn't clean up the wheel weights. Not that i would expect them to put the extra effort in or anything
Anyone know what chemical is good at softening this up and removing it? |
11-23-2016, 12:23 PM | #2 |
3069
Rep 5,577
I use BMW tar remover and BMW natural wax with a microfiber towel. And it takes quite a few applications before it disappears. But I noticed in cold temperatures the sticky glue doesn't want to disolve. That's why I do it when it's warm outside.
Isopropyl alcohol didn't work at all for me. And I refuse to use a plastic scraper or goo gone. I treat my wheels like my paint, never a bristled brush to clean them. |
11-23-2016, 12:52 PM | #3 |
452
Rep 986
lol thanks. I tried isopro alcohol as well, didn't seem to do anything. I use just microfiber on the face of the wheel, and then i will splurge with a brush on the inside of the wheel when it's off the car. I have a heather in my garage so i can make it warm
11-23-2016, 05:15 PM | #4 |
1165
Rep 1,931
heat gun.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
12-02-2016, 09:55 AM | #5 |
289
Rep 556
The commercial 3M General Adhesive Remover 08984, and a 3M 03612 4" x 5/8" Adhesive Eraser Wheel will remove any adhesive known to mankind.
Unfortunately, you can't purchase this commercial adhesive remover in CA; CT; DC; DE; IL; IN; MA; MD; ME; MI; NH; NJ; NY; OH; PA; RI; UT; VA; VI |
12-02-2016, 10:25 AM | #6 |
452
Rep 986
Wow lol.. I found plastic razor blades and gasket remover works too (it's acetone based be careful) Only let it sit for a few seconds, work at it with the plastic razor, and repeat.. It comes off pretty easily repeating those steps.
https://www.amazon.com/Permatex-8019...c+razor+blades https://www.amazon.com/CRC-05021-Tec...gasket+remover A bunch of forums referenced the spray version of that product too: https://www.amazon.com/3M-38983-Gene...hesive+remover |
12-02-2016, 01:20 PM | #7 |
1165
Rep 1,931
dude, heat gun for 5 seconds, comes right off. Nothing to scrape or use toxic liquids.
www.nybmwcca.org
12-03-2016, 11:36 AM | #9 |
452
Rep 986
Goo gone is pretty weak. It takes alot of work to get it off, and even once it's off it doesn't remove the final layer of adhesive. So far the gasket remover+ plastic razor blades are the ballz. Maybe next year i'll try that 3m Adhesive Remover, lot of detailing forums swear by it for everything.
FYI, i am removing left off foam/adhesive from the tire shop just popping off the weight. Not entire wheel weights. A heat gun would work much better for that. |
12-04-2016, 06:43 PM | #10 | |
Kingslayer
411
Rep 1,479
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
12-09-2016, 12:33 PM | #11 |
3805
Rep 2,860
Careful w/ those chems, to keep them off the tires. Some of these can mess up the rubber, and that could be a real drag if it caused tire failure at the bead.
12-09-2016, 09:12 PM | #13 |
Kingslayer
411
Rep 1,479
Tarminator won't hurt the rubber. It's actually great for cleaning the brake dust off of the sidewalls before spraying protectant (like 303).
03-29-2017, 03:27 PM | #16 |
140
Rep 671
I have a wheel balancer at home and all I've ever do is scrape the old weights off. it's just too much work trying to clean the inside of wheel weight goo.. Now if I had wheels where you could clearly see the inside... then in might be a different story..
'20 240ix convertible
