Keep battery alive with another car while flash tuning?
11-21-2016, 10:00 AM | #1 |
111
Rep 408
I can't seem to find this specific question via search. Anyone know if, while flash tuning with mhd, instead of using a charger, I can use another running car and jumper cables to keep my battery from dying? Good/bad idea? What would be the step-by-step for that?
Edit: Also if I do buy a charger, how many amps should it be capable of/is the car pulling, while doing such a thing? Last edited by FamilyManTrackSedan; 11-21-2016 at 10:24 AM.. |
11-21-2016, 10:33 AM | #2 | |
270
Rep 790
I was concerned about over charging. It worked. Oh yes, I made sure to turn off lights, turn off A/C, and I also pulled the fuel pump fuse. ECU backup took about 50 minutes. 1st flash took about 45 minutes I think. So I had to do them on 2 separate days (backup first). Last edited by lordbmw; 11-21-2016 at 10:44 AM.. |
FamilyManTrackSedan111.00 Jonah33554.00 |
11-21-2016, 10:42 AM | #3 |
111
Rep 408
A friend just handed me this thing: https://www.amazon.com/Schumacher-IP.../dp/B000ZIMK82
I'm now wondering if this is NOT the same as a battery tender, it doesn't seem to be a thing you keep plugged into the wall while using it, or if it won't overcharge my battery. |
11-21-2016, 10:47 AM | #4 | |
270
Rep 790
11-21-2016, 11:34 AM | #5 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
A charger will cost you all of $40 bucks and be VERY useful for the rest of your life. Yes you can do it the way you are saying but just spend the cash. It's small money and not worth the risk of something going wrong like a cable falling off causing damage.
11-21-2016, 12:52 PM | #6 | |
270
Rep 790
That was my problem. My parking lot has no electrical outlet at all. A Tesla car would be absolutely worthless to me right now. |
11-21-2016, 01:02 PM | #7 | |
111
Rep 408
Anyone know how many amps are drawn during flashing? |
11-21-2016, 01:10 PM | #8 |
Slow.
3782
Rep 7,151
For safety reasons I would flash at a location where you have access to AC and a charger, like a friends house, parents, etc. I get where you are coming from but I would only hook to another battery if it was my only option to get the car running and movable. Best of luck.
11-21-2016, 01:14 PM | #9 | |
270
Rep 790
11-21-2016, 01:27 PM | #11 |
Slow.
3782
Rep 7,151
god I can't read your name without hearing the announcer's voice.
11-21-2016, 01:28 PM | #12 |
Warrant Officer
375
Rep 1,341
It will work, just be mindful your halfing the amps when you connect the battery like that. I would just turn off as much accessories as possible on both cars in order to minimize the load on the alternator.
Deleted, ATM I/C and tuned by B.R.R.
FamilyManTrackSedan111.00 |
11-21-2016, 02:34 PM | #14 | |
Warrant Officer
375
Rep 1,341
I'm not an electrical engineer yet, still in school for it, so this shouldn't be taken as a definite solution.
11-21-2016, 03:15 PM | #15 |
285
Rep 615
Drives: '11 E92 335xi 6MT
It's my understanding that you'll have the best luck with an automatic charger that responds to the current draw. The main thing that draws power is the fuel pump running while the flash goes so if you pull the fuel pump fuse then you significantly reduce the electrical draw while flashing.
Black & Decker and Stanley sell the same automatic chargers with different branding in 15 and 25 amp versions. 15 amp - Stanley / Black & Decker 25 amp - Stanley / Black & Decker You should probably be fine with one of the 15 amp ones, even if you don't pull the fuel pump fuse. You can spend a little extra for the 25 amp ones if you want. The automatic feature should keep them from over-charging the car. The Stanley versions are a bit cheaper, at least on Amazon the 15 amp Stanley is $46 vs. $60 for the same thing branded as Black & Decker. But just look at them, it's the same charger. |
11-21-2016, 03:16 PM | #16 |
Slow.
3782
Rep 7,151
you just slap a meter on the battery cable to find out. well the meters we have at work at least
I never pull the fuse and just use mine on it's 10A setting.
11-21-2016, 06:40 PM | #17 |
111
Rep 408
this should do it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
11-22-2016, 06:43 AM | #19 | |
305
Rep 1,163
It's fine to connect to another battery. It's simply a parallel connection, and will provide the extra amperage needed. I've done 45 minute flashes with no charger. Adding a 5-10A charger or jumping from another battery for extra capacity is PLENTY.........
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
11-22-2016, 06:45 AM | #20 | |
305
Rep 1,163
Parallel = Double capacity (AMP hours) (Voltage stays the same) Series = Doubles voltage, capacity remains the same.
11-22-2016, 06:51 AM | #21 | ||
Warrant Officer
375
Rep 1,341
11-22-2016, 06:53 AM | #22 | |
1705
Rep 14,829
It seems that units that provide clean power @ 70 amp are in the $500 ballpark. The idea is that if the car starts drawing 70 amps, the voltage is a steady 13.8V. If you buy a $70 walmart charger that does 100 or 200 amps, as the car draws 70 amps, the voltage spikes up to 16 and electronics could be damaged. That's what I found through my research. People who have the money buy the right stuff. But, I had also identified that the power supplies for RVs are in fact identical, and cost a fraction of the price, and do provide clean power. What tipped me off to the power supplies used in the coding world, was watching the YouTube doing the ABS pump, I did not know what he had hooked up to his car at the time... |
