Carly can't find compatible ecu for coding on a z4, help
11-20-2016, 05:09 PM | #1 |
42
Rep 367
My friend just got a 2007 z4. He asked me to come over and do some coding. I brought my tablet with carly pro and usb cable. This tablet setup works great on my 335 e92.
When I connect to his car, the app connects. When i run the coding compatibility check it comes back and says it cannot find any compatible ecu for coding. When I run a diagnostic scan it only finds 1 ecu and shows a couple of error codes. Any ideas why this is happening? Bad ecu? The car runs fine as far as I know. My setup is a Samsung Galaxy tab s tablet with carly and the one stop electronic obd usb cable.
Vrsf fmic, vrsf charge pipe with bov, vrsf catless down pipes, afe intake, manzo exhaust, bms jb4, bms cowl filters, bms oil cooler valve, 19" Konig Oversteer wheels, wrapped up, hood vents, carbon fiber wing, custom headlights, air lift v2 airbag system
11-21-2016, 11:10 PM | #4 |
90
Rep 386
Drives: 08 535xi 11 328xi
did you select the correct chassis for the z4, you say it's a 2007 so it looks like it should be an e85/86 make sure you are not selecting e89. if that is not the problem then contact the developer at www.mycarly.com. they should be able to help you out.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
12-04-2016, 09:06 PM | #5 |
329
Rep 325
I believe the e85/86 needs to have pins 7&8 bridged on the kdcan....otherwise you can only run diagnostic on the DME & EGS(engine & trans).
rjahl, are 7&8 bridged on your Z4, not sure when the Z4 moved off the K-line. |
12-06-2016, 11:21 PM | #6 |
166
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
I bridge pins 7and 8 for my 2008 535
I remove the bridge for my 2011 Z4 For the 2007 you need to check those pins as mentioned in the previous post Last edited by NoQuarter; 12-06-2016 at 11:27 PM.. |
12-07-2016, 08:05 AM | #7 |
329
Rep 325
