11-20-2016, 02:54 PM | #1 |
217
Rep 602
Unable to connect to VIN to start coding
I am planning to start some basic coding/config changes and have hit an issue trying to connect via the VIN option in E-Sys.
The connection to VIN option is grayed out and it will not connect or refresh. Fault seems to be the PC is unable to assign an IP address that will allow the two to talk to each other. The Ethernet port is working if connected directly into a broadband router. I have tried disabling the firewall, AV and ensuring the ENET cable is secure. Has anyone hit this problem and if so, how did you resolve it pls? Thank you.....
Past BMW's: 2017 G30 530d MSport, 2015 F30 330d MSport, 2013 F10 520d MSport, 2009 E60 530d MSport, 2001 E46 330i MSport, 2002 E39 520i MSport
11-20-2016, 04:36 PM | #2 |
217
Rep 602
Well after some playing around, got it to connect via the VIN, but my token code was not working, so back to the drawing board, watch the coding demos on youtube and try again tomorrow.....
11-20-2016, 04:42 PM | #4 |
606
Rep 1,455
A few things to try :
When you connect the cable to the car make sure the ignition is on Wait (up to a couple of minutes) until the link is established, you need to make sure the Ethernet has limited connectivity Once this has happened you can do an ipconfig from the command line, check the IP addtress starts 169. as this denotes autoconfiguration has worked If not check that your IP settings are set to auto, ie you don't have a static address configured Turn off your wireless adapter. Try these steps first as it seems a pretty basic IP configuration issue I see you're based in Beds, I work in Dunstable so if you really cant sort it maybe we could work something else - if nothing else we could try my cable just in case yours is faulty |
S1NGH217.00 |
11-20-2016, 04:55 PM | #5 | |
217
Rep 602
So connection/cable is fine, just need to get the token to work by reading the instructions again, as its probably me.... If I get stuck, I might just take you up on your offer with a meet up in Dunstable. Thanks for the kind offer.
11-20-2016, 04:58 PM | #6 |
217
Rep 602
I think so, but I am checking it again in case it was human error....!
11-20-2016, 05:31 PM | #7 |
217
Rep 602
Can someone please send me a link to the latest coding instructions for E-Sys 3.28.1 please.
Just realised the one I have is out of date, and want to make sure I am using the latest instructions. Thank you
11-20-2016, 06:17 PM | #9 | |
217
Rep 602
Thanks Teaston.
11-21-2016, 04:19 AM | #10 | ||
10995
Rep 32,881
https://mega.nz/#!gkJHnb7C!ODXsSmtz5...YlVYuDq7qu7uYk |
S1NGH217.00 |
11-22-2016, 06:21 AM | #11 |
217
Rep 602
I have a cheat sheet, but i cannot find the following codes to change, can you help please.
1, Fog lights on with welcome lights. 2, Ignore LED fog light bulbs. Thank you
11-22-2016, 06:54 AM | #12 |
154
Rep 234
Quick q as this is the only coding post on p1.
Is there a minimum version of Windows for running the coding software? I have an ancient laptop that I'd hope does the job. Anything from the last 10 years though is OSX based.
now: 440i GC gone: C350 CDI estate, C250 CDI, A4 1.8T quattro |
11-22-2016, 07:45 AM | #13 |
606
Rep 1,455
I have esys running on Windows XP Pro without any issues
black stig154.00 |
11-22-2016, 09:36 AM | #14 | |
10995
Rep 32,881
2. 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold check for Front Right Fog Light. 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm check for Front Right Fog Light. 3061 NSW_R_IS_LED -> aktiv : Setting Front Right Fog type to LED. 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold check for Front Left Fog Light. 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm check for Front Left Fog Light. 3061 NSW_L_IS_LED -> aktiv : Setting Front Left Fog type to LED. |
S1NGH217.00 |
11-22-2016, 10:57 AM | #15 |
217
Rep 602
Its all working now and I have successfully coded for the first time, hooray...
Quite easy once you've done it once. Thank you Teaston & Sasquartch, much appreciated....
