Battery dead or parasitic power drain or alternator?
11-20-2016, 02:37 PM | #1 |
465
Rep 534
Been getting the dreaded increased battery discharge warning for a while now, and car failed to start last week, had to jump it, drove to dinner, then drove home no problem. The next day, same thing happened. Seems that letting the car sit for an hour or two for dinner is okay, but overnight it looses enough charge that it won't start.
I bought the Ctek MUS4.3 to charge/recondition the battery and ran it through the full cycle on Friday night. Yesterday car started fine, drove about 50 miles parked it for about 10 hours then went out for dinner drove another 15 miles to dinner, parked for 2 hours 15 miles back from dinner and had no trouble. This morning, get in and it won't start again. Here are the error codes I had today when i tried to start it: / 1) 2DED power management, standby current control // 2) 2D2A differential pressure sensor, suction pipe: adaptation // 3) 2E8D intelligent battery sensor, signal transmission // 4) 29CD Misfire, Cyl. 1 // 5) 2DEC power management, battery control // 6) 2DEB power management, vehicle wiring system control // 7) 2A38 Valvetronic, actuator: sluggish or open circuit // 8) 2ACC DME digital motor electronics main relay, switch delay // 9) 29DB engine roughness, segment time measurment |
11-20-2016, 04:02 PM | #2 |
90
Rep 386
Drives: 08 535xi 11 328xi
get your battery tested, most Auto parts store will do it for free. most likely the battery is bad.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
11-21-2016, 07:23 PM | #4 |
465
Rep 534
Thanks everyone...went to pep boys and they confirmed battery was shot so I replaced it.
Installed the battery car started right up, drove around for about 15 minutes got home parked, restarted the car and got the increased discharge warning again. Could be that I need to reprogram...went from Lead Acid to AGM and I also need to register. Hopefully that will fix the issue |
11-21-2016, 09:11 PM | #5 | |
Zeed
17
Rep 561
11-27-2016, 12:35 PM | #6 |
228
Rep 1,045
With a new battery
11-27-2016, 02:18 PM | #7 |
413
Rep 1,362
Was having a battery drain every 2 days.
Autozone said the battery was good BULLSHIT. Bought my new exide bat from carid and problem solved. No mor problems
11-30-2016, 02:20 AM | #8 |
465
Rep 534
Problem solved...was paranoid it may be more than just the battery but once I switched it out and finally figured out how to both code and register it, everything is working perfectly
11-30-2016, 03:17 AM | #9 |
Rep 34
This seems to be an issue for a lot of people. I've had it twice now. Just had my battery replaced for the second time in 6 months. Surely there must be something causing the batteries to fail?!
11-30-2016, 11:15 PM | #10 | |
465
Rep 534
I'll reply to this thread if any other issues come up, but hopefully this battery will last another 6 years or more...I'm now using a ctek 4.3 battery tender because I travel for work and sometimes leave the car parked for a week or two at a time |
