11-20-2016, 02:39 AM | #1 |
36
Rep 163
Dash cam: where to mount and power
Hi All, I'm thinking of getting a dash cam but looking for advice from those who have one.
1. Best value 2. Discreet mounting 3. Power installation Surprised bmw or other car manufacturers don't have these as optional extras. Thanks |
11-20-2016, 02:54 AM | #2 |
11
Rep 39
Looking for something similar, been contemplating several but Thinkware F770 seems the best as it has speed and traffic light warnings over and above the Qvia.
Id also be very interested in other thoughts. |
garethjonesuk36.00 |
11-20-2016, 03:02 AM | #3 | |
36
Rep 163
I don't really want to see it dominating the windscreen. I don't want to see wires. I definitely don't want to start ripping my car apart. Not much I know! Lol |
11-20-2016, 03:05 AM | #4 |
423
Rep 644
Hi
I recently installed the Thinkware F770 (front only) and it was a doddle to fit. It can be hardwired or run from a cigar lighter outlet which is what I did (there's a discreet one hidden below the glove box in my car). I ran the cable inside the head lining (you simply feed the cable in) then down the windscreen pillar between the rubber seal and the trim then across into the passenger footwear. I removed the passenger footwear trim panel (2x10mm bolts), coiled up the excess cable neatly and cable tied to secure then just plugged the cable into the cigar lighter. The cigar lighter cable exits the connector at 90 degrees so stays tucked up neatly and doesn't protrude down into the footwear at all. The camera itself is very neat and sits quite flat to the screen and was easy to set up (you connect your phone/tablet to it via wifi for live view via the Thinkware app to set up alignment and general settings). Hardwiring gives extra functionality for recording whilst parked and motion detection etc but I just wanted it purely for front recording so cigar lighter outlet was good for me, this outlet powers down soon after door locking so no issues with battery drain etc..........can thoroughly recommend the F770, £200 off ebay |
11-20-2016, 03:08 AM | #5 |
423
Rep 644
Thinkware F770 very discreet and I don't really notice it sitting behind the rear view mirror, my Mrs also says she doesn't notice it when she's in the passenger seat.........I forget it's there until it chirps up telling me I'm in a mobile camera area/average speed area.
11-20-2016, 03:10 AM | #6 | |
36
Rep 163
Do you have any photos of the cam mounted so I can get an idea of how busy the windscreen looks. Ta. |
11-20-2016, 03:13 AM | #7 | |
36
Rep 163
11-20-2016, 03:15 AM | #8 |
3719
Rep 8,636
Stuck my transcend DrivePro behind the mirror, can barely see it from drivers seat. Routed the cable into the headlining, down the a pillar and round the passenger footwell to the 12v socket under the glovebox. Dead easy and no wires on show.
garethjonesuk36.00 Twenty2Three208.50 |
11-20-2016, 03:19 AM | #9 | |
423
Rep 644
Will pop out and get some pictures soon and post them. The outlet in my car is next to the transmission tunnel but a bit further back into the footwell (hope that makes sense). Best thing is to look up under the dash from outside the car to see it (if you have it) |
11-20-2016, 03:24 AM | #10 |
423
Rep 644
I just made sure that I tucked the cable between the A-pillar trim and the rubber door seal but not inside the A-pillar trim itself as there's a airbag in it, I didn't want to risk any deployment issues due to the cable being inside the trim
11-20-2016, 03:34 AM | #11 | ||
36
Rep 163
11-20-2016, 06:48 AM | #13 |
423
Rep 644
Just a couple of pictures of the Thinkware F770 dash cam installed and the cable connected in the passenger footwell. The camera could have gone slightly more to the left and possibly up a bit more but I wanted to make sure the lens wasn't obscured by the black dots on the windscreen (the lens is located on the front left of the unit). The camera also unlatches from the mounting plate by sliding it to the right so you have to make sure you leave room to be able to do that. You'll see from the cable picture that the cable leaves the connector at a right angle so this help to keep it tucked up out of the way
11-20-2016, 06:59 AM | #14 | |
759
Rep 1,863
Have a look at the BlackVue cams. There was a recent thread about the Thinkware ones having software problems. Also using the cig lighter as a power source is no good for parking modes. You need to take power from the fuse box and battery. |
11-20-2016, 07:24 AM | #15 | |
423
Rep 644
I wasn't too fussed about the parking modes, hence I went for the cigar lighter option but the hardwire cable is only about £35, would be interested if anybody can pouint me in the right direction of how to wire it and which fuse location to plug into?? |
11-20-2016, 11:10 AM | #16 | |
30
Rep 107
Thanks |
11-20-2016, 11:46 AM | #17 |
144
Rep 341
I have f750 hardwired in so I have parking mode. The hardwire kit needs extending though, then I ran cable the same as the glove box way but carried on down the door seal the tucked under plastic trim all the way to the boot. I used piggy back fuse holders to connect into fuse box ( this way you can put it back to standard in minutes) and a nut near fuse box for earth. I can get a picture of connection if you want, but it's a bit dark outside but I can give it a go.
Got a photo. Permanent live from 161. Switched live 143. ( Got this from a thread on here somewhere ). Earth to holding nut. Last edited by ddc73; 11-20-2016 at 12:06 PM.. Reason: Photo added |
11-20-2016, 12:11 PM | #18 |
423
Rep 644
[QUOTE=psp888;20876277]Nice install, do you have any pictures front the outside? How discreet is out from the outside?
Thanks[/QUOT I don't have any from the outside but will get one tomorrow, it's hardly noticeable from outside to be fair |
11-20-2016, 12:13 PM | #19 | |
423
Rep 644
11-20-2016, 12:23 PM | #20 | |
423
Rep 644
Thanks |
11-20-2016, 12:30 PM | #21 | |
144
Rep 341
Switched 12v = 143 Negative or earth= any nut to body of car. Don't really know what you mean be 0 volt. Hope this helps. I got all connection info from a thead on here, just enter "thinkware f750 hardwire " into search on here. |
Hugrov423.00 |
11-20-2016, 12:53 PM | #22 |
759
Rep 1,863
Ok. Here's my BlackVue install.
I used fuse 153 boot light for the ACC, direct to battery (with inline fuse) for permanent 12V and chassis bolt for -ve. This means one tidy connection to the fuse box and everything else is hidden. There is no airbag in the A pillar, it's a lanyard. Route the cable(s)as others have down A pillar and along floor to boot. Last edited by Nobby Clark; 03-22-2018 at 05:30 PM.. |
garethjonesuk36.00 Hugrov423.00 |
