11-18-2016, 08:37 AM | #2 |
64
Rep 181
I'm also torn between the two. AA seems to make a little more power and torque right out of the box compared to the jb4 from what I've seen. But I like that the jb4 has 7 different maps (not that all of them are available yet). It seems like the jb4 has more room for customization, for lack of a better word.
2008 E90 M3 - Sparkling Graphite Metallic / DCT / slicktop / single hump
11-18-2016, 09:32 AM | #3 |
The Wolf
247
Rep 987
Drives: stuff
They're capable of the same dme-lying to achieve the same output, my personal opinion is the AA is expensive considering it has no other feature except lying about sensor outputs.
JB4 will reach their output no problem and can do a lot more for less $.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
11-18-2016, 10:20 PM | #4 |
284
Rep 360
I've had my jb4 on my 340 since 300 miles. No complains , easy to update , can read and delete codes . The app is a great feature you can data log and send it right to Terry from Bms , normally responds within a few ours . Great customer service !!
2016 340I build thread : http://f30.bimmerpost.com/forums/sho....php?t=1266037
11-19-2016, 11:16 PM | #5 | |
BimmerPost Supporting Vendor
24186
Rep 190,796
If you are planning on adding downpipe, upgraded turbos, methanol then it is the Jb4 for sure If you plan on keeping your car stock, it is a very tough decision to make. A8 has a very nice power curve and torque in the midrange, JB4 has lot more features and more maps to come. They just released a more aggressive map as well We do 14 days money back guarantee on both if you would like to test them and choose the one you like more
11-20-2016, 08:48 AM | #6 |
4916
Rep 115,980
11-20-2016, 10:08 PM | #7 |
13
Rep 149
Drives: 2016 340ix Msport mppsk
I'm curious as well. It would be the only mod I would consider. I'm new to tunes. I currenltly have the MPPSK
edit: I just saw a video of before an after bms air filter I may have to pick one of these up too the sound is hypnotizing Last edited by N33D4SP33D; 11-20-2016 at 10:30 PM.. |
11-20-2016, 10:33 PM | #8 |
24186
Rep 190,796
Intake can be used with both tunes
11-20-2016, 10:41 PM | #9 |
64
Rep 181
If I'm planning on doing a downpipe and intake, which would be my better option?
11-20-2016, 10:42 PM | #10 |
24186
Rep 190,796
Jb4 will be a better option in this case
f30m63.50 |
11-21-2016, 03:26 PM | #11 |
2253
Rep 3,622
The cost isn't really that different.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
11-27-2016, 11:14 PM | #13 |
enthusiast
116
Rep 221
Personally, (and I drove someone's car with BMS intake and JB4 map1 - no downpipe) I prefer my AA tune with stock intake (removed sponge and charcoal stripe) - no downpipe yet either. It pulls much stronger, easier to install and remove, and a great daily driver (already clocked 800 mi). I am planning to add the downpipe after winter and stick with AA. I wish the unit had the datalogging capability as JB4, however its fine as is to me since I wont add any more mods (after downpipe)..yet Ive seen AA hp/tq per rpm power increase, afr, boost and overall power curve.
Unless JB4 release much stronger maps (map2 is still weak as I read) on pump 93 gas and safe AFR, I dont see the point of JB4 over AA (cost difference is insignificant).. Datalogging is important when going crazy with mods.. which is not the case here..
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. |
11-28-2016, 01:46 AM | #14 | |
24186
Rep 190,796
Keep in mind you will get a code with downpipe with AA tune, JB4 hides it + other features for the JB4 (code reading, datalogging, boost by gear, Boost by RPM,etc...) I dont think one tune is better than the other, it comes down to what user is looking for
11-28-2016, 09:26 AM | #15 |
The Wolf
247
Rep 987
Drives: stuff
Just installed JB4, the logging, fault deletes and price make it the choice for me... AA is more and less functional, Terry can adjust the mappings with firmware on the JB4 whenever he sees fit and since they hack the same sensors on the engine I chose the one with an upgrade path.
11-28-2016, 11:13 AM | #16 |
126
Rep 369
Jb4 has deffinetly more room to grow. My biggest worry was the fact that the b58 is a new platform and if a serious engine failure occurs the car hasn't been flashed. I don't think they would blame anything on a tune but with my luck lately I didn't want take the chance. I'm not looking to break any records, just want more power with reliability. Don't feel the need to squeeze every possible bit out. As long as it continues performing stock like with the added power I'll be very happy. Can't go wrong wth either one but I do suggest AA tune if you want to set it and forget it.......
11-28-2016, 11:34 AM | #17 | |
4916
Rep 115,980
Mike |
11-28-2016, 12:45 PM | #18 | |
126
Rep 369
11-28-2016, 01:15 PM | #19 |
813
Rep 526
If you're concerned about warranty it may be a good idea to avoid clearing codes repeatedly. The car's flash memory stores a count for how many times codes have been cleared. We've had a customer come in with a denied warranty claim because his car had a memory showing that codes had been cleared thousands of times (indicating the use of a piggyback).
11-28-2016, 01:28 PM | #20 |
126
Rep 369
If your concerned about warranty don't tune at all but I know flashed tunes can be seen if you look hard enough. I've seen a ton of tuned beemers come through the place I worked for and they didn't really care until......it needed a motor. But the car looked obviously modified. i dont know every detail but I know a engineer from NJ flew in and after some diggin on his laptop he found enough evidence to bounce the claim.
eluded3038.00 |
11-28-2016, 01:46 PM | #21 |
4916
Rep 115,980
JB4 does not flash the ECU. The DME also does not store how many times codes have been deleted. I've never heard of anyone having a warranty issue from deleting faults but heard of plenty who did not delete faults and had issuesl. YMMV.
Mike |
11-28-2016, 02:20 PM | #22 |
126
Rep 369
Since the Jb4 doesn't flash, it's a piggy back like the AA but with more features. Either way, whatever the op chooses he will be super happy.
I don't think the dme stores how many times the faults were cleared as the isid cleared faults automatically after performing some test plans and ista-p after programing as well. I do know it stores how many times modules were programmed and some store how many times adaptations were cleared. But anything is possible. A German engineer I met at Bmw training told me that they can see much much more than we could as techs. Last edited by Roki187; 11-28-2016 at 06:02 PM.. |
