Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Got wheels from Dinan and they don't fit
      11-15-2016, 10:14 PM   #1
Jaghi
18
Drives: Wraith
Long story short, I only test fitted the front cause I knew I would have an issue. It is a square setup 19x9 et 38. I'm lowered all the way down on kW v3s and the wheel touches the spring and the perch. On dinan's shitty recommendation I got the 255/30/19 PSS tires as well. What MM spacer do I need to be clear on both the inner and the outer? Thanks
      11-16-2016, 07:58 AM   #2
asquared
E39
asquared's Avatar
No_Country
134
Drives: 2000 540i
Really depends how much clearance you have on the fender side and also how much camber you are running. Given that you say you are all the way lowered, it's hard to say without visually looking at it. Too many variables right now man to give you a clear cut answer, but you may have to roll your fender possibly if you haven't already. I had that problem with my 135i and I was able to run 10mm easy, but I clearly had room for that.
      11-16-2016, 08:01 AM   #3
Jaghi
18
Drives: Wraith
Well the fronts are plastic so you can't roll them. My guess is a 10mm spacer with a 235/30/19 tire
      11-16-2016, 10:43 AM   #4
asquared
E39
asquared's Avatar
No_Country
134
Drives: 2000 540i
Yea might get away with 10mm, but likely have to go to a smaller tire size like you mentioned. The PSS run a bit more square by the sidewall.
      11-19-2016, 08:46 PM   #5
techwhiz
techwhiz's Avatar
453
Drives: e90 335i Sedan - Arctic
You need to specify Pre-LCI or not and how much you are lowered.
I run 19x9 ET-35 in the front and a 19x9.5 ET-33 in the rear with 5mm spacers.
I'm running 245/35 in the front and a 275/30 in the rear and nothing rubs.
My car is Pre-LCI with Bilstein B8 shocks with negative camber with factory specs. I would think that a 5mm -10mm spacer should work.
5mm would mean ET-33 and in normal cases that would clear the spring perch.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
      11-22-2016, 07:20 AM   #6
Jaghi
18
Drives: Wraith
I have a pre-lci e92 with KW V3. I am lower them most E92, almost all the way down on the KWs
      11-27-2016, 04:11 PM   #7
Jaghi
18
Drives: Wraith
Here is a picture
      12-03-2016, 03:24 PM   #8
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Drives: '16 M3, '23 718 Spyder
Did you try to run a 5-10mm and camber it?
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      12-05-2016, 09:46 AM   #9
Jaghi
18
Drives: Wraith
With a 5mm I was golden, no need to touch the camber
      12-06-2016, 07:58 PM   #10
techwhiz
techwhiz's Avatar
453
Did you get the 5mm longer lug bolts?
You should, if you didn't.
      12-07-2016, 07:14 AM   #11
Jaghi
18
Drives: Wraith
The bolts that came with it seemed a bit longer then 5mm but yes I did. Thanks for following up!
