Can mismatched rims cause any damage?
11-15-2016, 09:33 PM | #1 |
Rep 38
Hey guys,
I m currently using my OEM 193m rims and they are staggered. They come 18x8 front and 18x8.5 rears So today i got winter tires for my rims 225/45 all around at "a large independent tire dealer". I specifically told the manager the wheels are staggered and to make sure the wider ones go in the back. After i got my car I had to go to work. I wasn't able to check if the wheels were on properly until the end of the day. Turns out front left is 18x8.5 and front right is 18x8 and same with the rears. I drove around 60km today can this cause any damage to a 2009 335xi? Thanks |
11-15-2016, 09:39 PM | #2 |
82
Rep 604
If your rims are staggered, so should your tire size. The mismatched rims is silly to do for a shop, but the mistake on your end was to get a square setup on staggered rims.
225/45 on a 8" wide rim is going to have a different rolling diameter then a 225/45 on a 8.5" rim. I cant tell you the exact difference of your wheels, but i know theres a chart somewhere on this forum, your wheels diameter is supposed to he within 1% of each other. Example would be; My 199 wheels are 8 front 9 rear, so respectively, 235/35 and 265/30. My winters are off a z4 but i believe they are 8.5 square, 225/45 all around. |
11-15-2016, 10:39 PM | #3 |
Rep 38
I read from a couple other threads its ok from people with xdrive and similar size rims. Visually they don't even look stretched so i can understand that they would mess up even though i specifically told the manager, a little disappointing.
Im wondering though can it cause any immediate troubles? Like would i need another alignment from driving a whole day with mis matched rims? or anything of the sort I did notice it slightly pulling to one side but that is because one rim is wider in the front |
11-16-2016, 01:22 AM | #4 |
82
Rep 604
Nothing immediate, but i believe it affects the transfer case and diffs, not cheap stuff.
I once helped a buddy who got a tire puncture, he has an xdrive and i took two of my spare winter wheels to swap on the back of his car, since the puncture was on the rear right. The wheels were same width, but the sidewall on his were 5 bigger than the ones i put on the rear,. The car barely drove 5kms to his house, the traction/transfer case was freaking out. Will not affect alignment, but i usually get one between wheel swaps, because im usually adjusting my suspension height at the same time. |
11-16-2016, 07:57 AM | #5 | ||
2341
Rep 3,541
And in your example 235/35 and 265/30 is actually a wrong setup. 35% of 235mm = 82.25mm 30% of 265mm = 79.5mm If you want to stay with 235s in the front, then your correct rear size is 275/30. 30% of 275 = 82.5mm As you can see that is the closes number to the 235 percentage difference. If you want to stay with 265 in the rear, then your correct front size is 225/35 35% of 225 = 78.75 As you can see that is the closes number to the 265 percentage difference. Cheers |
11-16-2016, 08:49 AM | #6 |
319
Rep 378
I am also running a square set up on stock 189s 8/8.5 for both my summer and winter sets. If an issue I could easily switch them out all 8s and the other all 8.5s but I did not think aboutt width effecting RD. how to you calculate the difference in rolling diameter for this set up?????
11-16-2016, 01:03 PM | #7 | |
82
Rep 604
The reason i didnt go 275 was when i test fitted it, it was just too big for my 9" rim, running PSS. OP, i found the chart you can refer to for the differences, looks like your setup is good, i was only speaking from experience and caution. Thanks Wolf for clearing up that the width wont make a significant difference. http://www.e90post.com/forums/showthread.php?t=1050762 |
11-16-2016, 02:54 PM | #8 | |
Rep 38
11-16-2016, 03:18 PM | #9 | |
2341
Rep 3,541
Sometimes you have to compromise rolling diameter, in order to get the fitment right. Speedometer will be off by a hair, but it's still all good! |
