11-15-2016, 11:01 AM | #1 |
20
Rep 21
Maintenance before winter storage
The only time I have had my vehicle in for service was after the 1200 break-in period. I am planning on storing my vehicle for the winter around December 1, so I made an appt. for this week to have the car serviced again (I'm at 7,500 miles). I'm not due for any specific service but I thought it made sense to get the car looked at before I put it away for a few months. The service center just called me and basically told me that there is nothing to do since I am not due for any service. Am I OK going without any service before I store the car? (Storage will just be a non-heated garage and I may still drive on nice days this winter.)
The only minor issues I have had are the tire pressure on my rear passenger tire (which I unfortunately had to replace after like 2 weeks because I got a flat; I have just filled it back up when low and it has been fine for a few weeks at a time but it seems like could be a slow leak?) and an intermittent message that pops up about automatic high beams not functioning correctly (I have never noticed any actual issue). Any thoughts would be appreciated. Thanks. |
11-15-2016, 11:44 AM | #2 |
1324
Rep 2,924
It's probably better to change the oil after storage. All the particles will sediment in the oil tank and will pass via the filter. A new oil/filter change will be better in the spring and you will use the oil (oil has a life limit as it oxides).
Hope it helps!
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
ParlorBoss19.50 |
11-28-2016, 08:31 AM | #4 |
388
Rep 876
You'll be fine changing the oil in the spring. If it's going to be sitting awhile, throw some Startron in a full tank of gas and over inflate you tires. If the rear tire is leaking air, have your tire shop remount it.
12-11-2016, 12:16 AM | #5 |
1622
Rep 3,402
With conventional oils the recommendation for storage was always to change the oil before because byproducts of combustion would bind to the oil which could lead to damage. One of the advantages of synthetic oils are that those particles don't bind to synthetic so I don't think its as much of a concern as back in the old days.
