Interesting problem with p0171 code n54
11-14-2016, 12:28 AM | #1 |
12
Rep 14
Before I start, I do want to say that I have done endless research for the past week just trying to figure it out but no solutions have been found. Well here goes...
Currently I a CEL of p0171 and only that code. I understand that code can be triggered by weak fuel system, vacuum leaks, o2 sensor, etc. However after performing a boost leak test directly from the throttle body, the only leak that was found was the pcv. That being said if it was the pcv causing the problem, shouldn't it also caused a p0174 and misfire codes? Additionally, I don't think that the fuel system is to blame because it would throw more codes at me and I would feel misfires, which i don't. The current symptoms are a small hesitation in throttle response, a little loss in power, idle 150rpm higher than normal. My theory is that it the Bank 1 sensor 1 o2 sensor has finally quit on me causing the short-comings in performance. Since it has been noted that the o2 sensors go out at about 100k. The car currently has 128k. Let me know what you guys think? |
11-14-2016, 07:28 AM | #2 | |
Enthusiast
167
Rep 1,622
11-14-2016, 11:14 AM | #3 | |
12
Rep 14
Update to this morning. I started it up and it had a 1 bad stumble, I gave it a bit of throttle and she was fine and even started to idle like normal; even after being warmed up. |
11-14-2016, 11:21 AM | #4 |
12
Rep 14
I have decided to bite the bullet and ordered the Bosch 17098 Oxygen sensor for the Bank 1 Sensor 1 replacement. It was $89.24 shipped with 2-day shipping from Amazon with the Prime trial so I can also watch the Grand Tour for a couple weeks
I'll keep you guys posted on how it goes. |
ArcticRik166.50 |
11-15-2016, 04:28 PM | #5 |
12
Rep 14
UPDATE! Because the idle returned back to normal last night, I decided to clear the code again and see if it came back. It hasn't come back just yet. I do admit that on Saturday I poured a full bottle of Techron Complete fuel system cleaner and drove it about 70miles since then. It might be possible that the cleaner is helping. Keep in mind that this is still pre-O2 sensor replacement. The loss of power and throttle hesitation have decreased slightly but are still present. I will keep on updates.
12-01-2016, 06:29 PM | #6 |
12
Rep 14
UPDATE! After changing the Front o2 sensor, it did not solve my issue with the p0171 code. I made a DIY on the change since I couldn't find one anywhere:
http://www.e90post.com/forums/showthread.php?t=1325770 PROBLEM SOLVED! On Thanksgiving I found that my Gas Cap was leaking fuel, which at the time I found odd because emissions checked it less than a month ago and it passed and I smelled no fuel. Long story short I changed the Gas Cap and erased the code, and after 1 week of driving it has not come back. Yay! |
12-01-2016, 09:10 PM | #8 |
73
Rep 236
Yeah good job. That code is a real bugger - I fought that one on a Jetta for months and never found it. Managed to get it to stay off long enough to achieve readiness and pass smog, then sold the car after disclosing it to the buyer. I think it needed a fuel pump and I didn't want to deal with it since I knew I was going to sell it.
