11-13-2016, 05:47 PM | #1 |
454
Rep 986
best vent mount for smartphone
What are the recommendations for solid vent mount smartphone holder. I'm playing with JB4 mobile, and i need something to hold it. I'd prefer vent mount.
i had one of these small magnetic ones, but it either wouldn't stay in the vent, or the phone would fall off https://www.amazon.com/WizGear-Unive...l+phone+holder |
11-13-2016, 06:56 PM | #2 |
197
Rep 258
Use the Wizgear Extra Slim with a Proclip USA dash mount. Works perfect.
https://www.amazon.com/WizGear-Unive...9084915&sr=8-6 ProClip: |
11-13-2016, 09:06 PM | #4 |
1165
Rep 1,931
i use the belkin vent clip now.
bottom line is after time they all start to fail. i have used suction cups, magnets, and the vent.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
11-14-2016, 07:02 PM | #6 | |
4516
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-14-2016, 07:09 PM | #7 |
454
Rep 986
I'm looking at trying this one.. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Although this Proclip doesn't look bad, the cost is interesting you have to buy the base then the actual mount, so it adds up too.. The only thing i don't like is that it holds the phone at the bottom. Does it rotate for landscape ? Is it held snugly in landscape that it won't slide out? |
11-14-2016, 09:26 PM | #8 | |
4516
Rep 8,942
2022 Macan S
11-15-2016, 10:13 AM | #9 | |
1753
Rep 2,942
Back then, the company was tiny, independent, and on the cutting edge of the niche along with RAM Mount (which I've also used, particularly for all-weather uses) and a couple of others. It's still fairly small -- It's based in Sweden -- and hasn't become too big for its own britches (as it were) like some others. It develops solutions based on hands-on research with each vehicle make and model, which makes the products fit about as well as can be expected without drilling or other methods that permanently alter your interior. The idea behind the two-phase ordering process is so you can use one bracket for one device on several vehicles, or one mount for several brackets/devices on one vehicle. In the long run it actually saves you money. The quality is slightly less than it was initially, but it's by no means bad. The vent mounts in particular are well designed and all but seamless. They just work. No, they're not that pretty, but no mount with multiple uses really is.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
11-15-2016, 08:13 PM | #11 | |
197
Rep 258
That's why I went with the Proclip/Wizgear. I actually have the Wizgear glued to the Proclip, with the metal base for the Wizgear inside my phone case. You can mount the phone any direction you want. I'm also running this setup in my truck. |
11-16-2016, 06:11 AM | #12 |
4516
Rep 8,942
Will post some pics of my proclip later w phone installled. If you run the wire properly there's only an inch or two exposed and it looks very clean - the whole setup looks a little clunky no phone that's true but with phone it looks very slick.
Biggest tip is to remove the proclip logo, plastic dip or spray flat black, and reinstall. It looks a million times cleaner without the logo, makes a huge difference.
2022 Macan S
11-16-2016, 07:12 AM | #14 |
63
Rep 99
I just ordered the Kenu Airframe+ after scouring the forums this past weekend. Looks like the simplest, most elegant one with the best reputation.
2017 M240i Cabriolet RWD 6MT. Glacier silver/coral red, alu hex/blk trim, moonlight blk top.
11-16-2016, 08:59 AM | #15 |
Rep 9
I really like this one Its called Mag'n'Mount
Looks good inside the car and holds the phone rock steady. I did wrap some electrical tape around the prongs that you insert in dashboards crevice to help keep it in place. Other types of mounts always seem to wear out over time or I couldn't place my phone in them without covering up some controls to something. Others would send my phone flying across in the car when making a turn. This has solved all those problems for me. |
11-16-2016, 09:20 AM | #16 |
454
Rep 986
Great feedback guys.. I got that shitty one from amazon.. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's a POS.. it only connects to the vent on the top, and the bottom is just a rest.. So you can't put the phone in one handed without it falling out.. crappy design |
11-16-2016, 09:52 AM | #17 |
228
Rep 301
Here's another Proclip example.
Holds it steady in either vertical or horizontal orientation. It also holds the phone away from the vent so that it flows air and the vent adjustments are still accessible and functioning. I have a vent/magnet mount in my 330i and it's OK; but the Proclip is superior. (I snapped this photo quickly to show an example and when looking at the photo I noticed that I really didn't have the phone placed properly in the holder. The right side of the phone actually sits a little more forward, and thus the phone is angled more toward the driver when properly inserted. Even when not inserted properly, the phone is secure.) |
11-16-2016, 10:36 AM | #18 | |
4516
Rep 8,942
2022 Macan S
11-16-2016, 12:12 PM | #19 | |
228
Rep 301
11-16-2016, 01:20 PM | #20 | ||
4516
Rep 8,942
2022 Macan S
11-16-2016, 01:34 PM | #21 |
14
Rep 36
Spigen Swivel mount is hands down the best car mount I've owned. I mount it on the passenger vent and the magnet is so strong that the phone will stick no matter how you orient it.
Blocks almost no buttons the way I have it set up. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
11-16-2016, 05:13 PM | #22 | |
1753
Rep 2,942
However, it will wear out fairly quickly, it's not very secure, and the weight of whatever is mounted in it can limit viewability options. It's good for what it is, but imperfect for long-term use in a single car.
