Staggered wheels for Xdrive?
11-07-2016, 12:21 PM | #1 |
22
Rep 93
19x8.5 ET35 in the front with a 235/35/19 tire
19x9.5 ET33 in the rear with a 265/30/19 tire I currently run Squared set-up but I want to transition over to a staggered set-up. My only concern is that my car is X-drive/AWD model. What should I keep in mind if I do this? Are there any draw-backs? Best, Richard |
11-07-2016, 12:41 PM | #2 |
65
Rep 411
The only thing you have to worry about is that they are within 1% diameter of each other otherwise it will mess with the x drive. I believe those sizes are fine though. Someone else can chime in to confirm.
11-07-2016, 03:53 PM | #3 |
28
Rep 177
Clarified your comment.
I believe chatch10 is correct. With those tires, you'll be at around 0.857% difference between front/back. |
11-07-2016, 05:53 PM | #4 |
Moderator
123
Rep 281
Those sizes would work just fine.
You could also get away with: 235/35-19 front 275/30-19 rear Those sizes would have the exact same overall diameter. The only drawback to stagger is that you will not longer be able to rotate your tires. So you will typically wear the rear tires about 2x as fast as the front. |
11-29-2016, 01:08 AM | #5 |
22
Rep 93
Thanks A LOT EVERYONE. How would 235-35-19 and 275-30-19 compare with the 235-35-19 and 265-30-19 set-up? Would there be a performance difference? what should I expect it to look? the Rears would stick out more?
