11-06-2016, 11:59 AM | #1 |
77
Rep 129
Drives: 2016 MW M235xi
H/K amp pinout and MOST bus connections
Hello everyone,
I am planning on upgrading the sound system in my H/K equipped M235 and have some questions about the amp wiring and MOST bus ring. I have decided to forgo the LOC and high level input DSP and instead use a mObridge DA3. This will allow me to utilize the higher sound quality optical MOST bus interface and a DSP all in one device all while maintaining factory volume and owner controls, where I can purchase said DA3 as a direct consumer is a different story. Anyway, I took out the trunk liner today to inspect the stock H/K amp wiring harness but could not find the MOST optical ring connections to the amp or ASD module. I did however find 3 optical connections into the (I believe) Bluetooth combox to the left of the fuse box under the trunk liner. My question is, is the HK amp not in the MOST ring and getting just an analog audio signal from some other module, and why are there 3 optical connections into the Bluetooth combox? The mObridge website says the f22 is supported with the NBT iDrive but I guess that means I'll just have to install the DA3 before/after the Bluetooth module. Any insight into the ways of the MOST bus interface would be greatly appreciated! Thank you. |
11-07-2016, 02:39 PM | #3 |
1753
Rep 2,942
Correct. Basically, with a few relatively minor exceptions (example: the output from the HU is balanced, so any amp added to the system must have differential balanced inputs), the 2 Series audio systems operates like a traditional/typical wired car audio system. Your best course of action is to get your hands on the wiring diagram for it, then plan accordingly.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> Last edited by Viffermike; 11-07-2016 at 03:38 PM.. |
gtmax50076.50 |
11-07-2016, 03:22 PM | #4 | |
191
Rep 314
11-07-2016, 03:39 PM | #5 |
1753
Rep 2,942
Yep! Post edited. Thanks!
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
11-07-2016, 05:07 PM | #6 |
77
Rep 129
Okay, thanks for the info guys. I guess ill give mObridge a call since they say it's compatible.
Any pointers on where to find the wiring diagram? My cursory Google/forum search did not yield anything. |
11-07-2016, 05:10 PM | #7 |
454
Rep 986
Scroll down a little in my post. Probably doesn't help, no MOST, just copper wiring.
http://www.2addicts.com/forums/showthread.php?t=1124786 |
gtmax50076.50 |
11-09-2016, 10:31 AM | #8 |
150
Rep 485
I'm planning to completely bypass the factory audio system in this car - I'll run digital coax from my FiiO X7 to my Helix DSP Pro and the rest of the system I'm taking out of my Audi.
11-10-2016, 09:09 AM | #9 |
191
Rep 314
The mObridge DA is actually compatible, but you will, however, need to add the mObridge into the MOST loop, making the install a little bit more involved, and code your headunit.
11-10-2016, 07:46 PM | #10 | |
77
Rep 129
Quick question, does it matter where I add it to the MOST loop or anywhere is fine? Maybe ill start a build log when I get all my parts in. |
11-11-2016, 05:16 PM | #12 | |
77
Rep 129
Since our head unit outputs analog sounds we will have to code it to output digital sound. |
11-11-2016, 06:18 PM | #14 |
191
Rep 314
The devices on the MOST loop are the headunit, instrument cluster and the combox for older cars (the TCB on newer cars isn't on the MOST loop). So you'll have to add it into the loop with the input and output going to the devices you are going in between. Diagrams added for clarity.
Before: After: Oh and if you don't have navigation/NBT headunit in your car then you probably won't have a MOST loop in the car at all, and the headunit will probably not have MOST sockets. Last edited by Gabrola; 11-11-2016 at 06:24 PM.. |
gtmax50076.50 |
